RLM - armrest (pics included)
RLM= really lame mod. just changed the armrest and it only takes 5-10 minutes. looks good up or down. [img]http://img.villagephotos.com/p/2003-10/423426/rest1.jpg[/img] [img]http://img.villagephotos.com/p/2003-10/423426/rest2.jpg[/img] [img]http://img.villagephotos.com/p/2003-10/423426/rest3.jpg[/img] [img]http://img.villagephotos.com/p/2003-10/423426/rest4.jpg[/img] [img]http://img.villagephotos.com/p/2003-10/423426/rest5.jpg[/img] [img]http://img.villagephotos.com/p/2003-10/423426/rest6.jpg[/img] [img]http://img.villagephotos.com/p/2003-10/423426/rest7.jpg[/img] [img]http://img.villagephotos.com/p/2003-10/423426/rest8.jpg[/img]
  • Replies 54
  • Created
  • Last Reply
[quote name='Th3Franz']So does the new armrest have more storage then?[/quote] From what I recall from another thread, the answer unfortunately is no :(. Kind of dumb in my opinion. Why make a solid piece of plastic. They could've just designed a nice big box!
-ben
$144 bucks. no extra storage. it does pop up to the right height and seems sturdy but i wouldn't crawl to the other side while its up. the top latch releases the top. it pops up, foward and latches in the up position. to put it back down you press the latch, puss it, and it snaps into the closed position. i also put the plastic hood protector (RLM) on today. made in australia. i wish subaru would either take the "subaru" lettering off or at least use flat black paint so it's not so obvious. p.s. on the other hand you could hide a couple of doobies where the mechanism is. :D :o
[quote name='Ken S']Does the extended arm rest still allow you access to the small storage cubby underneath it? How do you access that area? Ken[/quote] yes, you can still access the storage below. the latch is in the same place as the one you have now. the top surface of the armrest is the same as the original. the top opens for storage in either up or down position.
[quote name='red beast']$144 bucks. no extra storage. it does pop up to the right height and seems sturdy but i wouldn't crawl to the other side while its up. the top latch releases the top. it pops up, foward and latches in the up position. to put it back down you press the latch, puss it, and it snaps into the closed position. i also put the plastic hood protector (RLM) on today. made in australia. i wish subaru would either take the "subaru" lettering off or at least use flat black paint so it's not so obvious. p.s. on the other hand you could hide a couple of doobies where the mechanism is. :D :o[/quote] Looks great. Just curious as to where you got the armrest for $144? Was that delivered? thanks a lot Rob
[size=6]i'm special. [/size] got my armrest from liberty subaru. the parts department had one of each color on order for a long time. i went in on tuesday to order one, justin explained the story and said he would hold it for me. had feeling on saturday it was there, low and behold it was :D . i also picked up the plastic hood protector. :D both are installed. wanted both for my upcoing vacation in virgina beach. now to get the air filter for the interior. guess what? another subaru story. the filter is being redesigned. right now you have to take apart the dashboard to replace it. the filter should be changed every 12,000 miles and it cost an extra $100 in labor to change, hence the redesign. if you have one already you should have a sticker on a door jamb. door, or in the glove box.
  • 2 weeks later...
[quote name='mccorry']and......... :?: Do you like it? Was it worth the $$?[/quote] Well, from my point of view, I don't know how I lived without it -- when I put it down now, it just doesn't feel right. It does block the rear-most cuphold when it's exended. You can put a can of pop in it, but you have to put it in at an angle. I got my armrest for $118 and I think it was worth it Rob
  • 3 weeks later...
Anyone can advise where it can be bought? Am from singapore so likely need to order online... Also Singapore gets the Aussie model which comes with complete Momo intertior leather upholstery so wonder if the Black will "match" EA
  • 3 months later...
Do any of you guys have your elbow trigger the latch mechanism when shifting into 2nd or 4th gear causing the armrest to slide back on you? Just an observation not a big deal as it goes right back forward and relocks.
