quick4dr Posted February 5, 2010 Share Posted February 5, 2010 how does this log look. testes stage 1, stock intake. po852 on.romraiderlog_20100204_185858.csv Link to comment Share on other sites More sharing options...
mwiener2 Posted February 5, 2010 Share Posted February 5, 2010 that code is fort he neutral switch in the transmission. has nothing to do with your tune. The neutral switch is known for being fidgety. do a search on it My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
quick4dr Posted February 5, 2010 Author Share Posted February 5, 2010 never had an issue until loading stage 1 tune. any ideas for fixes? Link to comment Share on other sites More sharing options...
mwiener2 Posted February 5, 2010 Share Posted February 5, 2010 search neutral switch My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
quick4dr Posted February 5, 2010 Author Share Posted February 5, 2010 im searching, all i get is that theres a spacer issue, i never had any issue with stock map. it seems like if not the right map, it could cause it. Link to comment Share on other sites More sharing options...
mwiener2 Posted February 5, 2010 Share Posted February 5, 2010 no, it's most likely coincidence. There isn't anything in the tune that has to do with that switch, other than you're making more power. More power stresses things more. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Ridgeracer Posted February 6, 2010 Share Posted February 6, 2010 That tune is calling for 17psi of boost. Most stage 1 tunes only call for about 14psi. You under boosted the entire pull. What is the IAM currently? I opened testes1010 map and it really is a stage 1 map calling for 17psi. As for that log you posted, it seems like your IAM is changing during the pull. You should go to 1 as an initial starting point as per the map unless you have a lot of knock. Can you download Learn Viewer and post your findings. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
quick4dr Posted February 6, 2010 Author Share Posted February 6, 2010 reverted back to stock, not using his tune anymore. working on a mickeyd map now. thanks for all the feedback. Link to comment Share on other sites More sharing options...
mwiener2 Posted February 7, 2010 Share Posted February 7, 2010 Don't be surprised when that code comes back My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
