Th3Franz Posted April 20, 2015 Share Posted April 20, 2015 I installed my IAG AOS (Air Oil Separator) last weekend. With a built engine, I wanted an AOS with larger volume and designed to vent to atmosphere. I had a Crawford v2 AOS before and although it was working ok, I had to fix the hose connection at the crankcase so figured I might as well upgrade while I'm at it. The IAG AOS is HUGE. Dwarfs the Crawford AOS. More volume = better separation Some features I like about the IAG AOS: Dedicated connections to each head and the crankcase for better flow. No tees used.Huge outlet port. 1 in diameter. The large diameter reduces the velocity of the air traveling through, which may improve separation.Rotating top discharge port. You can install it in a variety of locations and point the discharge port in different directions.Coolant backplate. The coolant flows through the entire height of the AOS, keeping it warm and flashing off any condensed moisture inside the can.Serviceable. The AOS can is able to be opened up for cleaning or inspection. Potential improvements: Mounting bracket and hardware. The Crawford mounts way easier with its bracket design and two small bolts. The IAG AOS takes more effort but does have more adjustability. I think it could be improved.More space to tighten the coolant AN fittings. It's extremely tight to get a wrench square on the fitting to tighten it. They could have designed it to have more room to get in there.Provide hose clamps. Again, they include zip ties for the breather connections like the other AOS units on the market. Clamps would be nicer.Provide an option for a threaded fitting for the drain line. The oil drain line connection has a barb at least, but it would be nice if it had an NPT or AN connection where you could use either a barb or attach a hose with a crimped end on it for a leak free seal. I am not affiliated with or sponsored by IAG. I just found a product that fits my needs better and wanted to share my thoughts with the community and maybe have some discussion as well. Overall 8/10 product -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
boxkita Posted April 22, 2015 Share Posted April 22, 2015 Which one did you get - http://www.iagperformance.com/IAG-Performance-Engine-Air-Oil-Separators-s/2094.htm ? They list 2 (comp & street). Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Th3Franz Posted April 22, 2015 Author Share Posted April 22, 2015 I got the comp one -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
elgin.owens Posted April 28, 2015 Share Posted April 28, 2015 I've had my eye on one of the IAG Performance Race Series Air/Oil Separators for quite some time. On this super secret "Race" version they have used all AN fittings, which would address your need for a threaded fitting for the drain line. Here's some of the pictures they emailed me...http://i216.photobucket.com/albums/cc228/elginowens_photos/IMG_4207.jpghttp://i216.photobucket.com/albums/cc228/elginowens_photos/IMG_4205.jpg http://i216.photobucket.com/albums/cc228/elginowens_photos/IMG_4064.jpghttp://i216.photobucket.com/albums/cc228/elginowens_photos/IMG_4068%201.jpg Link to comment Share on other sites More sharing options...
quick4dr Posted May 13, 2015 Share Posted May 13, 2015 What is difference between street and competition models? What is best for a daily driven 20psi 05lgt Link to comment Share on other sites More sharing options...
Th3Franz Posted May 14, 2015 Author Share Posted May 14, 2015 I believe street routes the AOS outlet back to the turbo inlet / intake. The competition outlet goes to atmosphere. If you have a built motor I'd probably recommend competition. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 14, 2015 Share Posted May 14, 2015 I'm purchasing a street version for my stage 3 setup. Link to comment Share on other sites More sharing options...
quick4dr Posted May 14, 2015 Share Posted May 14, 2015 Just ordered the race version. Do you have notes from your install, I will be converting from grimmspeed aos, and IAG said they don't have instructions yet for the legacy. Link to comment Share on other sites More sharing options...
brawline Posted May 14, 2015 Share Posted May 14, 2015 It is the same as the 08-14? WRX. If you follow those instructions you will be fine. Ive run my IAG aos for 6 months? Got their version2 when it first came out. I also have the comp and i would suggest the comp one unless you have strict emissions and are worried about the aos dumping those vapors out and not back into the inlet. Link to comment Share on other sites More sharing options...
quick4dr Posted May 15, 2015 Share Posted May 15, 2015 I'm going to try and document my install as best as I can. IAG said it won't ship till next week. I also went for the pitch stop mount bracket set up, because j think it'll look better then mounted on the strut tower Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 15, 2015 Share Posted May 15, 2015 I ordered the Street version. Link to comment Share on other sites More sharing options...
quick4dr Posted May 20, 2015 Share Posted May 20, 2015 Oh boy received and installed my competition AOS today. Using the pitch stop mount bracket. Clearance is real tigjt because of the AC line the runs across the pitch stop mount. Quality is top notch. Still need to adjust fitment a bit Pitch stop mount bracket is a must if you are RacersX FMIC. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 20, 2015 Share Posted May 20, 2015 Any pics i am doing the street version with the pitch mount for my avo fmic Link to comment Share on other sites More sharing options...
quick4dr Posted May 20, 2015 Share Posted May 20, 2015 i can snap pics later but will be a while to post. i can txt them to you if want, just txt me 1-845-323-2553 Link to comment Share on other sites More sharing options...
elgin.owens Posted May 21, 2015 Share Posted May 21, 2015 Please do post the pics when you get time. I'm curious to see how the pitch mount worked out for you! Link to comment Share on other sites More sharing options...
quick4dr Posted May 21, 2015 Share Posted May 21, 2015 anyone know a trick to posting photos from an iPhone, it never works Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 22, 2015 Share Posted May 22, 2015 Mines on back order for two weeks. I guess i missed the production run for my color and the street version. Link to comment Share on other sites More sharing options...
quick4dr Posted May 22, 2015 Share Posted May 22, 2015 i got the new anthracite color its awesome. they said it was on backorder when i ordered too, then it magically showed up at my door in 3-4 days time. Only gripes: Wish pitch stop mount was longer so it could mount with more clearance over the AC hardlinethe runs across the firewall over the pitch stop mount. The recess for the cap head screws is machined with too tight of tolerance for the ridges on the cap head screws. And more space to tighten coolant line fittings would be nice. Photos soon i promise, i took them just need to post from a pc not a mac Link to comment Share on other sites More sharing options...
quick4dr Posted May 25, 2015 Share Posted May 25, 2015 pics Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 25, 2015 Share Posted May 25, 2015 Nice mines the same color. ordered from smy and they aren't receiving them for 2 weeks. it's next day after that though. Link to comment Share on other sites More sharing options...
quick4dr Posted May 25, 2015 Share Posted May 25, 2015 The color is fantastic. Build craft is superb. I enjoy mine, just need to angle the drain hose Fitting a little better for my install. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 30, 2015 Share Posted May 30, 2015 I love the quality just no right up or instructions on my model. I'm a little lost on the install. Link to comment Share on other sites More sharing options...
quick4dr Posted May 31, 2015 Share Posted May 31, 2015 Txt me 1-845-323-2553 I can guide you through/ send you video of my underhood Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 31, 2015 Share Posted May 31, 2015 I have the street version so i have the top three to locate. Link to comment Share on other sites More sharing options...
quick4dr Posted June 1, 2015 Share Posted June 1, 2015 those lines will go to the turbo inlet, follow the 08 wrx model. Link to comment Share on other sites More sharing options...
