Schrei Wolf Posted July 19, 2013 Share Posted July 19, 2013 Up until yesterday my A/C system has been running fine. These past two days have also been very hot. The A/C unit runs after sitting all night but once it warms up it short cycles like it's low on refrigerant but that's not the case. Any thoughts on this? Link to comment Share on other sites More sharing options...
Strizzy Posted July 19, 2013 Share Posted July 19, 2013 Are you running a FMIC? Did you recenty recharge your AC? My bad luck build Link to comment Share on other sites More sharing options...
Schrei Wolf Posted July 19, 2013 Author Share Posted July 19, 2013 No FMIC I recharged after it started short stroking. Link to comment Share on other sites More sharing options...
Strizzy Posted July 19, 2013 Share Posted July 19, 2013 It could be over-charged. My bad luck build Link to comment Share on other sites More sharing options...
FJuan Posted July 19, 2013 Share Posted July 19, 2013 Short cycles is an indication of low pressure in the system. - Low Freon - Bad compressor sensor - Bad compressor itself - Bad expansion valve My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Schrei Wolf Posted July 19, 2013 Author Share Posted July 19, 2013 Would the valve cause excess pressure in the low side or high? Link to comment Share on other sites More sharing options...
FJuan Posted July 19, 2013 Share Posted July 19, 2013 If you have check the pressure and the pressure looks good, then more than likely it's the compressor that's going out. If the compressor is not compressing enough pressure on the high side, the system will read low pressure and start cycling as a safety switch. A train mechanic would be able to determine this. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Schrei Wolf Posted July 20, 2013 Author Share Posted July 20, 2013 When I say short stroke it attempts to engage the clutch then immediately stops. Not like a GM were it runs for a few seconds and stop. Link to comment Share on other sites More sharing options...
Schrei Wolf Posted July 20, 2013 Author Share Posted July 20, 2013 Update: So I got to engage for a bit and the low side went back to it's happy pressure spot. Sensor or sticking Expansion valve Link to comment Share on other sites More sharing options...
Schrei Wolf Posted July 21, 2013 Author Share Posted July 21, 2013 If one were to replace their A/C compressor, Denso or Four Seasons? Link to comment Share on other sites More sharing options...
FJuan Posted July 22, 2013 Share Posted July 22, 2013 My preference would be Denso, and I've even installed rebuilt ones for other cars off of Ebay and had good success. Depends on your comfort level and price, rebuilts would be you're cheapest route. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
starionesir Posted July 22, 2013 Share Posted July 22, 2013 Would also say denso. Have you hooked up a set of gauges to check both high and low side pressures? Link to comment Share on other sites More sharing options...
Schrei Wolf Posted July 22, 2013 Author Share Posted July 22, 2013 Getting it checked out tomorrow Link to comment Share on other sites More sharing options...
