lamboman Posted August 9, 2005 Share Posted August 9, 2005 I would like to install a fire extinguisher. Do you have one installed? Show me a good place to mount one. In front of the driver seat? A-pillar? Please comment Link to comment Share on other sites More sharing options...
dark_rex Posted August 9, 2005 Share Posted August 9, 2005 are you planning on doing a lot of cooking in the car? Link to comment Share on other sites More sharing options...
melayout Posted August 9, 2005 Share Posted August 9, 2005 In front of the driver seat, if you want to lose the boys or not have kids. A-pillars have airbags. Also, why do you need an extinguisher? HPDE, SCCA, Serious track time? I keed I keeed Link to comment Share on other sites More sharing options...
MudRally Posted August 9, 2005 Share Posted August 9, 2005 Try HMS Motorsport for the 2 lb. extinguisher seat bracket mounting. Remove two front bolts, slide in the bracket and reinsert & tighten bolts per factory specs. The Impreza holes may match the Legacy, but I don't know for sure. http://www.hmsmotorsport.com/store/track-safety/fire/other-fire-ext-brackets Link to comment Share on other sites More sharing options...
RallyNavvie Posted August 9, 2005 Share Posted August 9, 2005 Hey, I always have an ABCD mini-extinguisher in my cars. Just because I may not use it doesn't mean I may need to help someone else. Plus I'm just so used to having one handy like in the rally car. I would try mounting it against the passenger side of the center console down in the footwell area. You may be able to pull back the interior there and get a good mount for it. That way it should be somewhat accessible from the driver seat but otherwise easily notices in case passengers should need to use it. Or if you don't really feel you need quick access to it or you sometimes transport little kids that may pop it try mounting it to the side of the trunk somewhere. I'm new to my LGT so I haven't found a home for mine yet, I'll probably do some serious looking before the next rally up here. Right now it's just in its plastic carriage in the right rear footwell. Link to comment Share on other sites More sharing options...
evil_O Posted August 9, 2005 Share Posted August 9, 2005 Just carry a can of Cold Fire: http://www.greaterthings.com/News/ColdFire/pr031122.htmlhttp://www.josephprep.com/ColdFire/index.html Link to comment Share on other sites More sharing options...
wukindada Posted August 9, 2005 Share Posted August 9, 2005 Way to R.I.C.E.R. for me........if it cooks down......GET A NEW ONE:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
sgt Posted August 9, 2005 Share Posted August 9, 2005 I keep my extinguisher in the trunk, or mounted to my roll cage.never anywhere else. Link to comment Share on other sites More sharing options...
TSiWRX Posted August 9, 2005 Share Posted August 9, 2005 Trunk for me - a mini as well. I've started too many small fires by accident *NOT* to have one near at all times. Why the trunk? I prefer to keep it out-of-sight and packaged where it won't get in the way of anything nor interfere with anyone's comfort. Certainly, it won't help if I'm trapped in the car, but I figure that I'd be screwed, in that case, anyway - and a seat-mount may nor may not have helped. It's a calculated risk that *I* chose to undertake. Why a mini? I'm no fireman, and I'm not deluded enough to think that even a bigger tank like I have for the kitchen will save me from an all-out "car-fire." I've seen too many of those to know better. I'll just step away from the car, and call for help. Mine is simply mounted through the carpeting in the trunk, behind my left wheelwell. The bottle is small enough/light enough that the bracket I made for it easily holds firm through the carpet. Even if I botched the quick-release in an emergency, I'll just tear the friggin thing out of the trunk, no problems. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
fishbone Posted November 7, 2008 Share Posted November 7, 2008 I'm going to revive this way old thread because I'd rather not start a new one. I also considered mounting it in the trunk but what if you get rear-ended hard, you need it but it has just become inaccessible. Anywhoo, the true reason I revived this thread is to ask something about fire extinguisher types. I have read that the standard dry type is next to impossible to clean up and also highly corrosive. Instead, for auto use it's recommended one purchases Halon-type extinguishers. Drawback? Expensive as hell http://www.nsxprime.com/FAQ/Accessories/fireextinguishers.htm Does anyone know of another type or can anyone recommend a not-so-corrosive one at a reasonable price? Link to comment Share on other sites More sharing options...
patriki Posted November 7, 2008 Share Posted November 7, 2008 Way to R.I.C.E.R. for me........if it cooks down......GET A NEW ONE:) In case you have valuables in the car.. ANY sort of fire will be an automatic write off. It only takes 2 minutes, max 3 for a car to burn down to bare bone (see pic below). Luckily, I didn't have too many valuables in the car, but for the stuff I did have, if I had an extinguisher then I'd be able to save it all. http://photos-a.ak.facebook.com/photos-ak-snc1/v275/162/21/227200822/n227200822_835904_9991.jpg http://photos-b.ak.facebook.com/photos-ak-snc1/v321/162/21/227200822/n227200822_905057_843.jpg Link to comment Share on other sites More sharing options...
Zs2.5 Posted November 7, 2008 Share Posted November 7, 2008 Here in Dubai all new vehicles from 2005 are required to have some sort of fire extinguisher installed in the vehicle from the manufacturer. Here is a pic of where Subaru installs them in the Legacy's here: Chris Link to comment Share on other sites More sharing options...
TSiWRX Posted November 7, 2008 Share Posted November 7, 2008 ^ Cool! Thanks! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
patriki Posted November 7, 2008 Share Posted November 7, 2008 That's actually a very good spot to put it IMO Link to comment Share on other sites More sharing options...
robinlsb Posted November 7, 2008 Share Posted November 7, 2008 I'm going to revive this way old thread because I'd rather not start a new one. I also considered mounting it in the trunk but what if you get rear-ended hard, you need it but it has just become inaccessible. Anywhoo, the true reason I revived this thread is to ask something about fire extinguisher types. I have read that the standard dry type is next to impossible to clean up and also highly corrosive. Instead, for auto use it's recommended one purchases Halon-type extinguishers. Drawback? Expensive as hell http://www.nsxprime.com/FAQ/Accessories/fireextinguishers.htm Does anyone know of another type or can anyone recommend a not-so-corrosive one at a reasonable price? If you get rear ended and there is a fire from a leaky gas tank, your are doomed. I keep a 5 pounder in the trunk. There is no other place, without bolting it to the floor, that is safe in case of an accident. Think of a five pond missile ricocheting around the cabin. I have saved three of my cars which had engine fires (very unlucky) The dry works fine, don't worry about corrosion. It is also a good idea to install a battery cut off switch. These new fangled cars can burn up, even if the ignition key is turned off. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
TSiWRX Posted November 7, 2008 Share Posted November 7, 2008 I have saved three of my cars which had engine fires (very unlucky).... Damn, that's impressive that you were able to save your vehicles. I've seen, up close and personal, how fast such fires can spread. I'm quite impressed. Like I said before, mine is where it is (and is what it is), for some very specific reasons. I have no delusions about being able to truly "firefight." I think that I'll likely invest in a front and a rear small-canister in-cabin setup as Zs2.5 posted (and thanks, fishbone for kicking my ass into doing something about it ), for some added peace-of-mind and safety. ---- patriki - What happened to your Rex?! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
j255c Posted November 9, 2008 Share Posted November 9, 2008 can u guys recommend me a small extinguisher to put in my trunk. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
NSFW Posted November 9, 2008 Share Posted November 9, 2008 Here in Dubai all new vehicles from 2005 are required to have some sort of fire extinguisher installed in the vehicle from the manufacturer. Here is a pic of where Subaru installs them in the Legacy's here: Chris That's really cool, thanks for posting that. Is there a Subaru part number for the bracket? Link to comment Share on other sites More sharing options...
robinlsb Posted November 9, 2008 Share Posted November 9, 2008 That's really cool, thanks for posting that. Is there a Subaru part number for the bracket? The fire extinguisher is too small. A five pounder is the smallest I would carry, and you better be quick! "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
TSiWRX Posted November 9, 2008 Share Posted November 9, 2008 ^ I think that in-cabin canister is only for extrication/standoff purposes. There's no way that can help a true engine-fire...... <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
nm Posted November 9, 2008 Share Posted November 9, 2008 ^ I think that in-cabin canister is only for extrication/standoff purposes. There's no way that can help a true engine-fire...... Honestly, that's the only reason to ahve a fire extingusher in the cabin. Too big and it's a pain in the cabin. And event I hope to particupate in a year or two requires me mount a 2.5 bottle within "easy reach" of the driver and I also need a spot for the navigator. Suggestions that don't require tearing up the interior? I don't need it in there all the time, just during runs. Link to comment Share on other sites More sharing options...
Zs2.5 Posted November 10, 2008 Share Posted November 10, 2008 That's really cool, thanks for posting that. Is there a Subaru part number for the bracket? Its not a "Subaru" part. It looks like it came as part of the extinguisher, which is from Italy. My Silverado and Trailblazer both have a 5 pounders mounted in about the same location. Most cars that have the room that I have seen have it mounted in that location as well. If not there they are usually in front of the drivers seat. I know all the American branded cars come with a 5 pounder! Chris Link to comment Share on other sites More sharing options...
fishbone Posted November 10, 2008 Share Posted November 10, 2008 Yeah, that insulation all around inside the dash that serves as noise deadening material ... that can burn awfully quick. Link to comment Share on other sites More sharing options...
NSFW Posted November 10, 2008 Share Posted November 10, 2008 ^ I think that in-cabin canister is only for extrication/standoff purposes. There's no way that can help a true engine-fire...... Sure, but having a small one in the passenger compartment, right at hand, still seems like a great idea. Maybe complement it with a bigger one in the back (where mounting should require a lot less creativity). Link to comment Share on other sites More sharing options...
TSiWRX Posted November 10, 2008 Share Posted November 10, 2008 ^ Exactly, and that's why I also do intend, as I said before, put two canisters in the passenger cabin (one front, one rear), for just such an emergency purpose. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
