branab3 Posted January 3, 2013 Share Posted January 3, 2013 I am sorry to do this and dont even know where this should be, but I have read through pages of threads to find this answer. I have an 05 LGT 5MT with 135K on it and have changed it in the past with Mobil 1 75W-90 LS front and rear. I have a noisy gear box and it shifts bad at high RPM's. I have read Redline 75W-90 NS for front and non NS for rear, Royal Purple, Valvoline, special S from Subaru. It is maddening and all the different opinions. Plain and simple, I want a quieter gear box that shifts better at high rpms, help! Link to comment Share on other sites More sharing options...
Aracheon Posted January 3, 2013 Share Posted January 3, 2013 Redline is what I run in my LGT. Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted January 3, 2013 Share Posted January 3, 2013 I just swapped to 3qts of Redline lightweight shockproof gear oil and .8qt motul 300.. the tranny is so much quieter, and doesn't bind or stick when shifting anymore. I couldn't be happier. Some of the gurus on here highly regard this cocktail. As for the rear diff, motul 300 has worked well for me. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 3, 2013 Share Posted January 3, 2013 Subaru Extra-S Why mix fluids that were never meant to be mixed when a Subaru branded product does the job better. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
branab3 Posted January 3, 2013 Author Share Posted January 3, 2013 Subaru Extra-S Why mix fluids that were never meant to be mixed when a Subaru branded product does the job better. I agree 100%, but it was said that it is not as "quiet" or as durable for higher heat conditions. That only matters because I am moving in February to Texas. What's you're experience with the noise? Link to comment Share on other sites More sharing options...
mwiener2 Posted January 3, 2013 Share Posted January 3, 2013 If you're tranny is so noisey that it bothers you, no fluid is going to fix that. You need a rebuild. Same goes for synchro issues. ExtraS is known to smooth shifts by allowing the synchros to perform better. But it's still just a fluid. If you have mechanical wear and/or failure, no fluid will fix that. As far as the heat, it's a full synthetic and it shouldn't be a problem. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Max Capacity Posted January 3, 2013 Share Posted January 3, 2013 I just swapped to 3qts of Redline lightweight shockproof gear oil and .8qt motul 300.. the tranny is so much quieter, and doesn't bind or stick when shifting anymore. I couldn't be happier. Some of the gurus on here highly regard this cocktail. As for the rear diff, motul 300 has worked well for me. This is the cocktail your going to want to use. In the years I've been here, this seems to help the most when you having noise and shifting issues. You can thank BAC5.2 for this cocktail. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 3, 2013 Share Posted January 3, 2013 I just swapped to 3qts of Redline lightweight shockproof gear oil and .8qt motul 300.. the tranny is so much quieter, and doesn't bind or stick when shifting anymore. I couldn't be happier. Some of the gurus on here highly regard this cocktail. As for the rear diff, motul 300 has worked well for me. I've put hundreds of thousands of miles on that "cocktail" to date. There's nothing wrong with Extra-S, but I'll stick with what I've been using for the better half of a decade now. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted January 3, 2013 I Donated Too Share Posted January 3, 2013 Subaru extra-S from what I've seen, read, heard, tried, etc Link to comment Share on other sites More sharing options...
Flipapotimus Posted January 3, 2013 Share Posted January 3, 2013 i want to remember this Link to comment Share on other sites More sharing options...
06legsleeper Posted January 3, 2013 Share Posted January 3, 2013 my buddy just went to redline , and im going to redline as well .... used it in all 3 of my bmw,s and always worked great .. great cold weather shifting. never had a problem with it .. they make one without the friction modifer that goes into the trans , one with modifers goes in the diff Link to comment Share on other sites More sharing options...
branab3 Posted January 3, 2013 Author Share Posted January 3, 2013 This is the cocktail your going to want to use. In the years I've been here, this seems to help the most when you having noise and shifting issues. You can thank BAC5.2 for this cocktail. That's cool. Thanks because I have seen this more than once as a good combo. I found Redline at Summit which is about twenty minutes from my house but now I will look for Motul. It's not that it is too noisy, it just is a noisy gearbox and they always have been. I remember the subaru guys at the race track calling these the "chatter box" and they always had some mystical secret gear oil formula they swore by. Being a Honda guy, we used motor oil for the gear box. Thanks Link to comment Share on other sites More sharing options...
branab3 Posted January 3, 2013 Author Share Posted January 3, 2013 This is the cocktail your going to want to use. In the years I've been here, this seems to help the most when you having noise and shifting issues. You can thank BAC5.2 for this cocktail. Oh yeah, what about the 3 qts part? I thought the front took more? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 3, 2013 Share Posted January 3, 2013 You buy 3 qt of the redline and two qt of the Mutol 300. put the 3 qt of redline in and top it off with .8qt of the 300. the rear diff takes about .8qt of the 300 also. Being a Honda guy my self, we used Honda manual tranny fluid in the race car and all Honda manual trannys. My son still has about 5 qt's left in the basement. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
06specb366 Posted January 3, 2013 Share Posted January 3, 2013 just changed mine out to straight motul. I'm pretty happy with it in the cold. Had negative temps the past couple nights, no issues. As far as going to Texas... not sure, but I've read good things about it in all temps. Just make sure its GL5 or higher and you should be good. Link to comment Share on other sites More sharing options...
06specb366 Posted January 3, 2013 Share Posted January 3, 2013 Oh yeah, what about the 3 qts part? I thought the front took more? BTW... mine took 3 liters, not quarts, plus rear diff Link to comment Share on other sites More sharing options...
branab3 Posted January 4, 2013 Author Share Posted January 4, 2013 You buy 3 qt of the redline and two qt of the Mutol 300. put the 3 qt of redline in and top it off with .8qt of the 300. the rear diff takes about .8qt of the 300 also. Being a Honda guy my self, we used Honda manual tranny fluid in the race car and all Honda manual trannys. My son still has about 5 qt's left in the basement. Which is basically 10W 30 motor oil! I was a line tech at a dealership for nine years and raced them and built them. Now I own a Subaru! Honda is a lack luster for me these days. I am having trouble finding Motul locally and now it makes sense, thi must be that magic formula for that gear box. Redline 75w-90 shock proof, this one right? http://m.summitracing.com/parts/red-58404 for front, 3 qts and Motul 300, .8 qts added to Redline and another .8 for rear. 3 redlined and two Motuls. Sorry to be so stupid but I only want to go up there once! I can't find Motul anywhere locally. Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 4, 2013 Share Posted January 4, 2013 AZP can get you the Motul. You want Lightweight Shockproof. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted January 4, 2013 Share Posted January 4, 2013 just changed mine out to straight motul. I'm pretty happy with it in the cold. Had negative temps the past couple nights, no issues. As far as going to Texas... not sure, but I've read good things about it in all temps. Just make sure its GL5 or higher and you should be good. Hmm.. I just swapped away from that.. I had a lot of gear noise, and the shifter was sticky. It was scary how much better the transmission likes the cocktail. I have heard of people running straight Motul in STI's.. maybe it's a 6mt vs. 5mt thing. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 4, 2013 Share Posted January 4, 2013 Which is basically 10W 30 motor oil! I was a line tech at a dealership for nine years and raced them and built them. Now I own a Subaru! Honda is a lack luster for me these days. I am having trouble finding Motul locally and now it makes sense, thi must be that magic formula for that gear box. Redline 75w-90 shock proof, this one right? http://m.summitracing.com/parts/red-58404 for front, 3 qts and Motul 300, .8 qts added to Redline and another .8 for rear. 3 redlined and two Motuls. Sorry to be so stupid but I only want to go up there once! I can't find Motul anywhere locally. "3qts of Redline lightweight shockproof gear oil and .8qt motul 300" That's for the tranny. The rear diff get's .8 Motul 300 SO you need to buy 2 qt's Motul 300 3 qt's Redline lightwieght shockproof You can buy it all from Mike at AZP. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
branab3 Posted January 5, 2013 Author Share Posted January 5, 2013 Thanks Max, I had to run out before checking it, but with the car down because shafts being replaced, I needed to do something quick. Summit Racing is just down the road from me so I got Redline Lightwieght Shockproof straight for the front and ran Redline 75W-90 for the rear. BTW, Redline LT wt shockproof looks like Smurf Gammi. All they had in stock for the rear was the non NS, but having a sealed viscous coupling, I figured it didn't matter additive or not. End result, the car shifts with unimaginable ease and smoothness. Glides into gear. As far as the noise, it definatley got quieter, actually kind of creepy quiet, only because I am used to hearing the whining under acceleration and feeling the notchiness of the shifter. The rear fluid was golden brown, and I hate to admit it, it was the first time changed, ever. Very very little metal on the plug. The plugs came out no prob, despite being bathed yearly in salt for the past 8 years. Now, I still have a "backlash-ish" noise while accelerating and is proportionate to the wheel speed, in or out of gear. The noise gets louder as the speed increases. I am suspecting Diff Carrier bearings? Is this a common ailment for these? I can only conclude this because the noise is related to wheel speed and gets loud when accelerating, quiets down when let off the throttle. I can't think it is the shaft as it is brand new and the noise was exactly the same before replacing it. The front wheel bearing have been replaced within the past twelve months and this noise was present before the replacement. That is why I fell it is carrier bearings. If so, that 6MT swap is looking real inviting for many reasons. I onestly have never had a vehicle with so many tranny problems and I wish I could take the credit of beating the crap out of it regularly, but I can't! Link to comment Share on other sites More sharing options...
