Nichomas Posted March 20, 2013 Share Posted March 20, 2013 What are the best mods to start with? Probably more simple things, not looking to rebuild my engine right now Link to comment Share on other sites More sharing options...
Baddog Posted March 20, 2013 Share Posted March 20, 2013 Suspension. Biggest upgrade you can do. I've put together some basic N/A builds and they are fun. But you already have a 2.5 and all mine have been 2.2's with frankenmotors. Link to comment Share on other sites More sharing options...
Zues Marine Posted March 20, 2013 Share Posted March 20, 2013 depending on the shape and mileage of the motor, first thing i'd consider doing is the Seafoam treatment.. after a tank of that, -Oil/filter change ($30) -NGK V-Power Copper Spark Plugs ($10) -NGK 8mm Plug Wires ($60) -MSD 8239 Ignition coilpack ($80) -8mm Grounding Kit ($15) these are the basics that will tune up your motor so it lasts though the future mods and utilize all available mpg after that you can go one of a couple different ways, suspension and aesthetics for looks, youre pretty much limited to the jdm market.. although 'limited' is incredibly misleading as these cars had massive aftermarket support there.. JDM projector headlights ($250) are an incredible upgrade and one of my favorite mods ever, just modify the projector to compensate for the RHD cutoff or aim it a bit lower so you dont blind other drivers.. JDM second gens are '93-'98 so any parts you stumble across with that title or bg5, will fit with the exception of motor stuff . . . . here: http://legacygt.com/forums/showthread.php/second-gen-aftermarket-parts-and-upgrade-guide-superceded-147261.html Link to comment Share on other sites More sharing options...
Nichomas Posted March 21, 2013 Author Share Posted March 21, 2013 Any recommendations on brakes or coilovers? Link to comment Share on other sites More sharing options...
Zues Marine Posted March 21, 2013 Share Posted March 21, 2013 for brakes, fronts at least..bugeye wrx calipers and their brackets will allow for an 11.7" rotor, and is also a bit wider too, better ventilated in the rear, outback H6 model rear brakes are significantly larger than stock and make the car feel like it is 'squatting' under braking then get some stainless steel lines and ebc pads and youll be more than happy coilovers- if you're not going for and insane track car but instead a spirited daily driver.. raceland ultimo coils made for the gd impreza give a decently priced bolt on option any 04 sti coils will also bolt up with the exception of the rear tophats... theyll need to be swapped with original legacy ones Link to comment Share on other sites More sharing options...
Fire Away Posted March 21, 2013 Share Posted March 21, 2013 depending on the shape and mileage of the motor, first thing i'd consider doing is the Seafoam treatment.. after a tank of that, -Oil/filter change ($30) -NGK V-Power Copper Spark Plugs ($10) -NGK 8mm Plug Wires ($60) -MSD 8239 Ignition coilpack ($80) -8mm Grounding Kit ($15) How many MPG can one typically expect to see from all of that stuff? Just a return to something close to original MPG or 1-2 extra? Link to comment Share on other sites More sharing options...
colby Posted March 21, 2013 Share Posted March 21, 2013 check for any bushings that are worn out and replace those. short shifter and so on. a bigger rear sway bar will help alot i hear. Link to comment Share on other sites More sharing options...
Sludgeroo Posted March 22, 2013 Share Posted March 22, 2013 check for any bushings that are worn out and replace those. short shifter and so on. a bigger rear sway bar will help alot i hear. The rear sway bar and rear strut tower brace are a huge deal for the wagons as they are significantly less rigid than the sedans. Link to comment Share on other sites More sharing options...
pleaidestar Posted March 22, 2013 Share Posted March 22, 2013 Suspension mods are definitely the best thing to start with on any car, then on to a clean running motor, then get some sticky z-rated tires and you will be cornering like a mini-cooper, taking 90° turns at 40 mph. fun times. Link to comment Share on other sites More sharing options...
Zues Marine Posted March 22, 2013 Share Posted March 22, 2013 Suspension mods are definitely the best thing to start with on any car, then on to a clean running motor wat. Link to comment Share on other sites More sharing options...
pleaidestar Posted March 22, 2013 Share Posted March 22, 2013 wat. I guess I should have said subjectively f your motor is running good, footwork makes your power linear. Link to comment Share on other sites More sharing options...
gergeek Posted March 24, 2013 Share Posted March 24, 2013 better tires is probably the best thing you can do for handling, then a rear sway bar....and then what everyone else said. MOST OF ALL research, research research...then invest. its really easy to dump alot of money into cars Link to comment Share on other sites More sharing options...
