hifonic Posted December 11, 2007 Share Posted December 11, 2007 Hi am new to the suby scene and just had a question about my car (05 LGT).Well the car fell's like the car is hesitating at around 3k rpm and above.The car is stock accept for a borla axle back exhaust and that's it.IDK like it is'nt building boost maybe?Any help or suggestions would be greatly appreciated.thanks for your help ahead of time Link to comment Share on other sites More sharing options...
Scoobeedooby Posted December 11, 2007 Share Posted December 11, 2007 You may want to do a quick search about stuttering... There are LOTS of threads like this.. Most say that an access port will do the trick in getting the stutter to relax... But more than likely its just the stuttering problem and nothing to be worried about... Just annoyed about! Link to comment Share on other sites More sharing options...
hifonic Posted December 11, 2007 Author Share Posted December 11, 2007 IDK it only does it sometimes but it's annoying as hell when it happens Link to comment Share on other sites More sharing options...
Jacks GT Posted December 11, 2007 Share Posted December 11, 2007 Its the main problem people have with these cars. There are allsorts of rumors about what causes it but there seems one easy way out either get the ECU reflashed by your dealer or get an COBB access port. Link to comment Share on other sites More sharing options...
hifonic Posted December 11, 2007 Author Share Posted December 11, 2007 So then this is a reocurring problem? Link to comment Share on other sites More sharing options...
Lothar Posted December 11, 2007 Share Posted December 11, 2007 So then this is a reocurring problem? Yes it is. Take a look at this poll. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted December 11, 2007 Share Posted December 11, 2007 say hello to the stutter Link to comment Share on other sites More sharing options...
Denver133 Posted December 11, 2007 Share Posted December 11, 2007 It's the way that these cars are. My new 08 Spec B does the same thing. I have my preorder in for my AP to get flashed to Stg 1 for now and hopefully that will smooth it out. It did for my 06 wrx. Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2007 Share Posted December 12, 2007 Nah. Mine does not stutter, ever. Link to comment Share on other sites More sharing options...
subiedude Posted December 12, 2007 Share Posted December 12, 2007 I'm stage II, and one time I went to pass a really slow driver... and went to pass. The car was like as if I was being held back by a chain. Not sure if this was an engine or 5EAT problem. Getting the trans valve body done thispring nonetheless. Link to comment Share on other sites More sharing options...
hifonic Posted December 12, 2007 Author Share Posted December 12, 2007 Well hearing that other people have had the same problem is a good thing I guess... Link to comment Share on other sites More sharing options...
whobaru Posted December 12, 2007 Share Posted December 12, 2007 Mine stuttered like a beehotch at certain times under certain conditions...mostly when taking off from a stop light on a hot day in the summer. A TDC stage 1 tune for my APV2 solved the problem. I've forgotten all about it. Link to comment Share on other sites More sharing options...
RangerMan Posted December 12, 2007 Share Posted December 12, 2007 Mine never stuttered. Two different ECUs (fan relay). Common problem though Link to comment Share on other sites More sharing options...
hifonic Posted December 12, 2007 Author Share Posted December 12, 2007 well then hopefully after some ECU mods the stuttering will go away Link to comment Share on other sites More sharing options...
whobaru Posted December 12, 2007 Share Posted December 12, 2007 I can almost gaurantee it. Link to comment Share on other sites More sharing options...
hifonic Posted December 12, 2007 Author Share Posted December 12, 2007 Good deal Link to comment Share on other sites More sharing options...
