Car "Hiccups"???
So while driving, in any gear, my car gets the hiccups... About 2-3k rpm, the engine cuts out and catches again instantly. The lights or cabin fan doesn't die, just the engine. Just quick enough to make the car jerk real quick, then on it goes like nothing happened. It is pretty random, sometimes twice in a day, sometimes not for a week or two.
Any suggestions of where to start with this issue? Fuel related maybe?
Thanks!
Pic for your time- Car in question
http://i.imgur.com/uRDrC.jpg
Fuel pump, dirty fuel filter, O2 sensor, dirty throttle plate, failing inlet air solenoid, dirty (or going bad) injector(s). Just a couple of quick thoughts.
Not in my experience - with three different NA Subarus - no material or quantitative performance difference over OEM.
I am having the same problem but My has only been doing it in the rain
fill a spray bottle with water and spray it around the engine, coil, wires at night with the car running. look for the lightning.
if you see it, replace the corresponding part.
