Linux Posted May 30, 2014 Share Posted May 30, 2014 Been reading up and now its about time to start putting some money into my wagon. Can we run the wrx/sti intakes? They pop up on ebay searches, ive looked around here and the almighty google and cant get an diffinitive answer. I would love to get it ordered this weekend. And possible the speedyracer headers to go with it Link to comment Share on other sites More sharing options...
Zues Marine Posted May 30, 2014 Share Posted May 30, 2014 no. stay with an OEM accordion style Jpipe from a 95-96 EJ22 for the maximum effective air velocity into the Throttle Body Link to comment Share on other sites More sharing options...
Linux Posted May 30, 2014 Author Share Posted May 30, 2014 Pull on from a scrap yard? Will it give the loudness? or will i need to do the snorkus delete? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 30, 2014 Share Posted May 30, 2014 If youre going for sound, removing that snorkus is what will give it to you.. pair that with a cone filter and it will sound noticeable.. heads up though, removing the snorkus will cause a MAF voltage spike in the lower RPM Link to comment Share on other sites More sharing options...
Linux Posted May 30, 2014 Author Share Posted May 30, 2014 any way around that? end all goal is going to be around 250hp without a swap or turbo, i wanna push the 2.5 as far as i can. Can the 2.5rs parts be used on these motors? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 30, 2014 Share Posted May 30, 2014 yes, the 2.5L is the same EJ25D throughout the Impreza/Forester/Legacy from about '96.5-'98.5 but I can tell you right now, 250hp wont happen without a swap or turbo..even dudes running super high compression and built internals are barely-if at all reaching that..not to discourage you, but it'll end up more cost efficient with a swap Link to comment Share on other sites More sharing options...
Linux Posted May 30, 2014 Author Share Posted May 30, 2014 Well damn, was trying to stay N/A, and i just like my car and dont want to do stupid amounts of stuff to it. Well looks like I will be buying the ej20t off of my buddy then Link to comment Share on other sites More sharing options...
SockMonkey Posted May 30, 2014 Share Posted May 30, 2014 I just recently did the intake swap from the 95 EJ22 onto my 97 2.5GT. Its not loud by any means, but it definitely sounds much better under acceleration. Link to comment Share on other sites More sharing options...
Linux Posted May 30, 2014 Author Share Posted May 30, 2014 That is really what I am wanting. More noise but not obnoxious...till i do exhaust and stuff, then loud is nice Link to comment Share on other sites More sharing options...
Stevo F Posted May 30, 2014 Share Posted May 30, 2014 I recently added the '96 intake tube to my '98. Not much louder but has helped MPG's and performance (also running an MSD coil). Link to comment Share on other sites More sharing options...
Linux Posted May 30, 2014 Author Share Posted May 30, 2014 MPGs are just gravy, Im looking for oomph Link to comment Share on other sites More sharing options...
Linux Posted June 3, 2014 Author Share Posted June 3, 2014 Can anything be done with the intake manifold itself? or can all that be done is change how much air gets to it? Link to comment Share on other sites More sharing options...
Zues Marine Posted June 3, 2014 Share Posted June 3, 2014 Intake Manifold spacers Link to comment Share on other sites More sharing options...
Linux Posted June 3, 2014 Author Share Posted June 3, 2014 are they actually worth the money? Link to comment Share on other sites More sharing options...
corlon Posted June 5, 2014 Share Posted June 5, 2014 N.o.s. ? Link to comment Share on other sites More sharing options...
DJBRANDER Posted June 5, 2014 Share Posted June 5, 2014 If youre going for sound, removing that snorkus is what will give it to you.. pair that with a cone filter and it will sound noticeable.. heads up though, removing the snorkus will cause a MAF voltage spike in the lower RPM Please elaborate. What is a snorkus? lol I put the 2.2 pipe, and the cone filter in mine Link to comment Share on other sites More sharing options...
erickrocks1126 Posted June 5, 2014 Share Posted June 5, 2014 yes, the 2.5L is the same EJ25D throughout the Impreza/Forester/Legacy from about '96.5-'98.5 but I can tell you right now, 250hp wont happen without a swap or turbo..even dudes running super high compression and built internals are barely-if at all reaching that..not to discourage you, but it'll end up more cost efficient with a swap ^^This right here. OP expectations might be a bit high. Think of it this way...the outgoing WRX was at 268HP crank (only 18HP more than your goals) with turbo at nearly 1 bar of pressure; the old 3.0 was NA at 250HP, but had relatively high compression and needed premium unleaded. The EJ25D is a good engine, but not 250HP good on its own. Even if you wanted to add boost, the 25D doesn't like it: http://legacygt.com/forums/showthread.php/2nd-gen-engine-faq-turbos-mpg-engine-builds-engine-swaps-167968.html Link to comment Share on other sites More sharing options...
Linux Posted June 6, 2014 Author Share Posted June 6, 2014 Yeah was going to try and stay with a NA motor. Would the H6 bolt up fairly easily? Link to comment Share on other sites More sharing options...
erickrocks1126 Posted June 6, 2014 Share Posted June 6, 2014 Yeah was going to try and stay with a NA motor. Would the H6 bolt up fairly easily? ??? That I don't know. You might want to check the stickies...I thought there was one dedicated to swaps and the like. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 6, 2014 Share Posted June 6, 2014 Please elaborate. What is a snorkus? lol I put the 2.2 pipe, and the cone filter in mine the snorkus... 'intake silencer' is the inner-fender box that sticks out in two places into the bay... connecting the airbox to the little black air thing about the headlight Link to comment Share on other sites More sharing options...
Zues Marine Posted June 6, 2014 Share Posted June 6, 2014 Yeah was going to try and stay with a NA motor. Would the H6 bolt up fairly easily? the H6 requires a lot of heavy modification to get it to fit in, the radiator and condenser end up being placed on a custom radiator support bar that extends into the bumper beam.. a couple dudes have done it before in the Legacys before though Link to comment Share on other sites More sharing options...
erickrocks1126 Posted June 7, 2014 Share Posted June 7, 2014 the H6 requires a lot of heavy modification to get it to fit in, the radiator and condenser end up being placed on a custom radiator support bar that extends into the bumper beam.. a couple dudes have done it before in the Legacys before though ^^Anything is possible with enough will, time, and most of all...money! To the OP: if you're looking for more power, then honestly it might be cheaper to save up and get a new or newer used LGT (if you're looking to stay in the Legacy line). Doing a motor swap or even converting from NA to forced induction could well end up costing you the same amount (counting cost of the car, labor, and parts). If cost isn't a factor, then disregard. Otherwise, just a thought to consider. Link to comment Share on other sites More sharing options...
Linux Posted June 9, 2014 Author Share Posted June 9, 2014 I am wanting to stay with the Legacies, I have had a GT and an OB and are by far the best cars Ive owned. I actually have my eye on an 06 LGT at the moment Link to comment Share on other sites More sharing options...
dudewerx Posted June 16, 2014 Share Posted June 16, 2014 So I have the Cosmo racing adapter plate for my 96 and I removed the snorkus when I installed it but I knew nothing about the voltage spikes at low rpm.... I haven't noticed a decrease in performance, actually the opposite. Increase in pull, grunt, and mpg. So what does the voltage spike do? Is it harmful and how do you fix it? Link to comment Share on other sites More sharing options...
vinnycogs Posted June 21, 2014 Share Posted June 21, 2014 I recently added the '96 intake tube to my '98. Not much louder but has helped MPG's and performance (also running an MSD coil). What kind of MPG's are you getting now compared to before? Link to comment Share on other sites More sharing options...
