gt06unlimited Posted December 28, 2012 Share Posted December 28, 2012 So, my CD player load/eject mechanism is jammed and my CD player does not work. My question is which is most cost effective... fixing the factory radio and applying a CleanSweep (or similar) product, or ordering the JDM dash kit mentioned on here and switching to a double DIN radio. I like the way the factory radio looks but if I have to send the radio out to be repaired or replaced, its probably cheaper to buy the dash kit and new radio. of course it depends on which head unit I buy, I'm more or less looking for what other people have done in this case. I did my best to see inside the CD slot but those little fabric flaps get in the way... I cant see a CD stuck in there, but if I try to insert a CD it makes it about an inch before it binds. =( Thanks! Link to comment Share on other sites More sharing options...
AkumaMax Posted December 28, 2012 Share Posted December 28, 2012 Well there is one other way you can go and thats the P-204UH headunit. Much sexier looking than the 05-06 headunit but they are a pita to come by. After buying just contact SVXdc for the AUX mod and no more need for CD's. Link to comment Share on other sites More sharing options...
Lucid Posted December 28, 2012 Share Posted December 28, 2012 It sounds like cost effectiveness is your primary concern. I imagine that buying a used head unit from a member will be cheaper than getting yours fixed. They come up for sale regularly here. Here's a recent example: http://legacygt.com/forums/showthread.php?t=198613 Link to comment Share on other sites More sharing options...
gt06unlimited Posted January 18, 2013 Author Share Posted January 18, 2013 Cool thanks for the link and information on other options Link to comment Share on other sites More sharing options...
mrmegadeth Posted January 18, 2013 Share Posted January 18, 2013 Had the same issue. I ended up taking the whole system apart just to get the jammed CDs out. I had to remove the head unit and then disassemble it. While you cannot get all the way to the magazine you can get to the mecanism and manually turn the gears that drive the eject. I did this an greased it up and pop...all of the CDs came out. I stuck a dummy back in and it jammed again...so I just consider it dead to me now. Link to comment Share on other sites More sharing options...
_karu_ Posted March 12, 2013 Share Posted March 12, 2013 Had the same issue. I ended up taking the whole system apart just to get the jammed CDs out. I had to remove the head unit and then disassemble it. While you cannot get all the way to the magazine you can get to the mecanism and manually turn the gears that drive the eject. I did this an greased it up and pop...all of the CDs came out. I stuck a dummy back in and it jammed again...so I just consider it dead to me now. mrmegadeth, based from your experience, do you think it's possible for me to take out the 6 CD changer unit from my car and replaced it with the single CD player from 05-06 unit? My 6 CD changer jammed too. I'm planning to take the system apart and try to unjammed it just like you did. I was just wondering if it's possible at all to replace it with the single CD unit.... Link to comment Share on other sites More sharing options...
CDubbs Posted March 18, 2013 Share Posted March 18, 2013 I had a jam problem when the first jazzy kit came out. You can attribute the line in the instructions to "eject all CDs first" to me. I was able to turn it right side up and come down through the top with a scribe to put the CDs back into place. I then connected the large harness to the back and powered it up and ejected the CDs, they reloaded fine. No, the name has nothing to do with bragging about 20 inch wheels... Link to comment Share on other sites More sharing options...
_karu_ Posted March 18, 2013 Share Posted March 18, 2013 I managed to disassemble the CD changer and take all the CDs out. Unfortunately, though the load mechanism appears to be working, it won't take the CD and play it. It would try to play the CD but then ejects it after making some noises. I just consider it dead now. Link to comment Share on other sites More sharing options...
ylime Posted August 11, 2013 Share Posted August 11, 2013 my cd player just did this and I took it apart and fixed the stuck cd, but when i got it put back together it didn't work at all, it is almost like there was never a cd player option in the stereo. The screen doesn't even recognize that there are cd's in there and when you press cd on the right side button nothing happens. I am hoping I can install my leptronix and it will still work. Link to comment Share on other sites More sharing options...
IndyBlitzen Posted July 27, 2018 Share Posted July 27, 2018 MY Current situation...can't even remember what's in there? Easter egg A,B ...?? Link to comment Share on other sites More sharing options...
