dflinn Posted March 22, 2012 Share Posted March 22, 2012 I have a noise while boosting in every gear and i have no idea wheres its at. I have no lose in power and my turbo is in perfect shape. When i hit around 5 psi and on i can hear a noise kinda sounding like a jack brake on a big rig like somthings sucking for air. I still hit peak boost but have no idea what it is any ideas? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2012 Share Posted March 22, 2012 Do you have an aftermarket air intake? Provide a sound clip or HD video. Link to comment Share on other sites More sharing options...
dflinn Posted March 22, 2012 Author Share Posted March 22, 2012 no its all stock except for stage two tune and ive tried to video the sound but all you can hear is my exhuast, the noise is right up front in the engine bay Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2012 Share Posted March 22, 2012 Do you have a K&N air filter panel? They are direct replacement of the paper one and fit in the air box. And have you had that sound since you've had the car? Link to comment Share on other sites More sharing options...
dflinn Posted March 23, 2012 Author Share Posted March 23, 2012 facter air filter and everything and no it started about a month after taking it to stage two Link to comment Share on other sites More sharing options...
dflinn Posted March 23, 2012 Author Share Posted March 23, 2012 factory air filter ** Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 23, 2012 Share Posted March 23, 2012 Then we have to wait for people with stage 2 to chime in. Since we can't actually hear your engine sound, it's hard to diagnose. But my current guess would be that since you're stage 2, turbo may be sucking more air now, thereby hearing the wooosh sound coming from the air intake better than before. I may be wrong. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 23, 2012 I Donated Share Posted March 23, 2012 Uppipe leak. Link to comment Share on other sites More sharing options...
dflinn Posted March 23, 2012 Author Share Posted March 23, 2012 but a thicker gasket on my up pipe where it bolts to the turbo unless its where it bolts to the header Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 23, 2012 I Donated Share Posted March 23, 2012 but a thicker gasket on my up pipe where it bolts to the turbo unless its where it bolts to the header Could be either. And is the UP-to-turbo gasket the stacked sheetmetal type, or that metallic paper stuff? Link to comment Share on other sites More sharing options...
dflinn Posted March 23, 2012 Author Share Posted March 23, 2012 stacked metal type its a 7 layer one 22% thicker than the stock one Link to comment Share on other sites More sharing options...
Cyclozene Posted March 23, 2012 Share Posted March 23, 2012 As people said it could be a gasket. I have a gasket leak on the downpipe and it sounded horrible. Like a fluttering noise. —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
suba Posted March 23, 2012 Share Posted March 23, 2012 I have a stage 2 tune with aftermarket up/down and stock filter. I have quite a noticeable turbo sound under any kind of boost, though I bought the car in its current setup so I can't vouch for before and after stage 2. Link to comment Share on other sites More sharing options...
dflinn Posted March 23, 2012 Author Share Posted March 23, 2012 yeah mines just like a flutter but imma try all new gaskets and check my intake Link to comment Share on other sites More sharing options...
Cyclozene Posted March 23, 2012 Share Posted March 23, 2012 If it's not the gasket it could be your wastegate which is natural. As you build the boost in your car the wg will go fap fap! it prevents your car from overboosting. I'm sure someone else will chime in —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
dflinn Posted March 23, 2012 Author Share Posted March 23, 2012 yeah im thinking if i adjust my wastegate it'll help i posted this on nasioc to and they said my wastegate needs adjusting so imma give that a try and see what happens Link to comment Share on other sites More sharing options...
Cyclozene Posted March 23, 2012 Share Posted March 23, 2012 Don't touch your wastegate. It's either broken or its not. And if you aren't overboosting leave it alone. It's designed to do that —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
dflinn Posted March 27, 2012 Author Share Posted March 27, 2012 okay but what about an intake leak somewhere? Link to comment Share on other sites More sharing options...
Cyclozene Posted March 27, 2012 Share Posted March 27, 2012 It could be your throttle body coupler but it's hard to tell. Post a video —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
trackhore Posted March 28, 2012 Share Posted March 28, 2012 sounds like typical stage 2 wastegate flutter to me. but I'm not riding shotgun, so my opinion is useless. Link to comment Share on other sites More sharing options...
GSlegacy Posted March 28, 2012 Share Posted March 28, 2012 check you MAF sensor to make sure its not loose, also check the TMIC to see if the hose has collapsed. If you have a bov check the lines that are connected to it to make sure there is no leaks Link to comment Share on other sites More sharing options...
Cyclozene Posted March 28, 2012 Share Posted March 28, 2012 I can almost be 100% sure that it is waste gate flutter. It is normal! —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
dflinn Posted March 28, 2012 Author Share Posted March 28, 2012 okay im just new to this whole turbo deal and it just didnt sound right to me but i thank everyone for helping out Link to comment Share on other sites More sharing options...
