Minty762 Posted August 11, 2015 Share Posted August 11, 2015 So I've been doing some research on the site about camber bolts and I'm not sure which ones I need/want. First I went through this thread which says to use the aftermarket 14mm bolts in the bottom hole maxed out to dial in negative camber: http://legacygt.com/forums/showthread.php/camber-bolts-82963.html Then I came across this thread suggesting you use 16mm bolts in the top position because they can be tightened to factory torque specs: http://legacygt.com/forums/showthread.php/1-9-degrees-front-camber-w-beefy-16mm-ingalls-81280-90790.html So which one is better? Stronger? allows for more camber? I've seen some other threads where people insist not to install bolts in the upper position. If anyone could provide some insight that'd be great. Link to comment Share on other sites More sharing options...
