HuRRiC4Ne Posted August 7, 2012 Share Posted August 7, 2012 Hey guys, i'm getting P0031, P0134 & P2097... Anyone know what the part number is for the Front O2 sensor? I went to O Reileys and they had a upstream and downstream O2... I'm assuming the Upstream is the front, the only thing is they wanted $179 for it. So I would like to try to find it cheaper. But I can't seem to nail down the exact part No. Also, anyone know the location of the Front O2? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 7, 2012 Moderators Share Posted August 7, 2012 (edited) Call napa autoparts, I got mine there for $8X.XX I think. It was a denso sensor. EDIT: location different because 2.5i Edited August 7, 2012 by BarManBean "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 7, 2012 Share Posted August 7, 2012 (edited) Hey guys, i'm getting P0031, P0134 & P2097... Anyone know what the part number is for the Front O2 sensor? I went to O Reileys and they had a upstream and downstream O2... I'm assuming the Upstream is the front, the only thing is they wanted $179 for it. So I would like to try to find it cheaper. But I can't seem to nail down the exact part No. Also, anyone know the location of the Front O2? DENSO Part # 2349123 OE Style / Air Fuel Ratio Sensor; Upstream $77.79 from http://www.rockauto.com The front 02 sensor is on the upstream side of the stock manifold catalytic converter: http://i144.photobucket.com/albums/r182/GEE-OTTO/hdr1.jpg Edited August 7, 2012 by GEE-OTTO Link to comment Share on other sites More sharing options...
subaruonlineparts.com Posted August 7, 2012 Share Posted August 7, 2012 If you want to PM me your VIN I can specify between the 2 possible front o2's One sells for 149 and the other 134 , These are original OEM -Benny Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 7, 2012 Moderators Share Posted August 7, 2012 If you want to PM me your VIN I can specify between the 2 possible front o2's One sells for 149 and the other 134 , These are original OEM -Benny Isn't the Denso the same as OEM? Just doesn't come in a subaru box so it's $50 cheaper? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 7, 2012 Share Posted August 7, 2012 If you want to PM me your VIN I can specify between the 2 possible front o2's One sells for 149 and the other 134 , These are original OEM -Benny There is only 1 part number for the Front AFR/02 sensor for our cars and that is the one DENSO makes all others are trash. DENSO is OEM so paying the stealer more money for the same part makes 0 sense Link to comment Share on other sites More sharing options...
LegacyDan Posted August 7, 2012 Share Posted August 7, 2012 If you want to PM me your VIN I can specify between the 2 possible front o2's One sells for 149 and the other 134 , These are original OEM -Benny can you do that with jdm VIN's aswell? Link to comment Share on other sites More sharing options...
Osei Posted August 8, 2012 Share Posted August 8, 2012 There is only 1 part number for the Front AFR/02 sensor for our cars and that is the one DENSO makes all others are trash. ... Not so fast. Bosch (the originators of O2 sensors) are great. Have replaced 3 in 3 different vehicles and never had a problem with them. Put over 40k on one in a 97L and no codes when I pulled the engine and junked the car. As a matter of fact that 2.2 was just swapped into a 98 Forester and it is just as happy. O. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 8, 2012 Share Posted August 8, 2012 Not so fast. Bosch (the originators of O2 sensors) are great. Have replaced 3 in 3 different vehicles and never had a problem with them. Put over 40k on one in a 97L and no codes when I pulled the engine and junked the car. As a matter of fact that 2.2 was just swapped into a 98 Forester and it is just as happy. O. Ok Bosch LOL Link to comment Share on other sites More sharing options...
subaruonlineparts.com Posted August 8, 2012 Share Posted August 8, 2012 Isn't the Denso the same as OEM? Just doesn't come in a subaru box so it's $50 cheaper? In most cases Denso is the original manufacturer , I have seen Bosch as well though Link to comment Share on other sites More sharing options...
subaruonlineparts.com Posted August 8, 2012 Share Posted August 8, 2012 There is only 1 part number for the Front AFR/02 sensor for our cars and that is the one DENSO makes all others are trash. DENSO is OEM so paying the stealer more money for the same part makes 0 sense Depending on the original destination of the vehicle there are 2 choices. 22641aa15a and 22641aa33a . It could be the difference between Cali and Fed. emissions. A VIN clears this right up. Perhaps the aftermarket uses one for both applications?? -Benny Link to comment Share on other sites More sharing options...
subaruonlineparts.com Posted August 8, 2012 Share Posted August 8, 2012 can you do that with jdm VIN's aswell? Usually not , I can try however Link to comment Share on other sites More sharing options...
HuRRiC4Ne Posted August 8, 2012 Author Share Posted August 8, 2012 If you want to PM me your VIN I can specify between the 2 possible front o2's One sells for 149 and the other 134 , These are original OEM -Benny PM Sent, Thanks! Link to comment Share on other sites More sharing options...
Tehnation Posted July 26, 2019 Share Posted July 26, 2019 DENSO Part # 2349123 OE Style / Air Fuel Ratio Sensor; Upstream $77.79 from http://www.rockauto.com The front 02 sensor is on the upstream side of the stock manifold catalytic converter: http://i144.photobucket.com/albums/r182/GEE-OTTO/hdr1.jpg where did you get that part number from? I thought it was Denso 234-9120 Link to comment Share on other sites More sharing options...
rhino6303 Posted July 26, 2019 Share Posted July 26, 2019 where did you get that part number from? I thought it was Denso 234-9120The part number from your quoted post os for an N/A legacy. You're correct on the 234-9120 for an LGT upstream sensor. Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 26, 2019 Share Posted July 26, 2019 Rockauto.com and be happy. I know some will say Go OEm or bosch which is great if you have the money. butI have ran some 65-70 dollar rockauto 02 sensors for 100k miles on my subies. car ran great. Link to comment Share on other sites More sharing options...
