sixspeedlegacy Posted May 28, 2011 Share Posted May 28, 2011 Hi Guys, Can the inner DOJ and shaft be ordered apart from the outer stub setup? I only ask because I will need to swap my outer stubs onto the Spec B shaft and would rather save money if I can buy the parts separately and put it together instead of buying the full assembly and taking it apart and buying another separate outer stub. I was on opposed forces but having a hard time figuring out what the names were for things and what the number references were. Any info would be great. Thanks! Ben Link to comment Share on other sites More sharing options...
sixspeedlegacy Posted May 28, 2011 Author Share Posted May 28, 2011 I was told you do need to buy the full axle because the outer stub is considered non-serviceable by subaru so you can't get it separately. Ben Link to comment Share on other sites More sharing options...
