carguyco Posted May 5, 2012 Share Posted May 5, 2012 slow speeds.....usually when turning....in a parking lot. Rattles from drivers side wheel area.... I haven't put it up on a lift...but what would be the most common culprit? 70k on car..all stock, 2nd owner, first owner didn't do anything to the car was a lease. I am a dumba** when it comes to suspension...I have read every thread in this section looking for hints. Thanks in advance.. sounds a little like a golf ball in a paint can.... Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 5, 2012 Share Posted May 5, 2012 I'd say worn tophat on the strut, or loose swaybar end link. It could also be the ball joint possibly. Link to comment Share on other sites More sharing options...
Death Posted May 6, 2012 Share Posted May 6, 2012 loose heat shield? I replaced a half-shaft thinking that was the noise when in reality it was just the heat shield bent into the driveshaft. my catalytic converter on my mazda used to make that sound like it had marbles in it. Link to comment Share on other sites More sharing options...
charlie_sheen Posted May 6, 2012 Share Posted May 6, 2012 my cobb sf intake rattled at the filter for the longest time. i went through loosening and re-tightening my entire fmic piping and then discovered it was my air filter. Link to comment Share on other sites More sharing options...
