youlikeit Posted March 12, 2012 Share Posted March 12, 2012 Ever since I've had my RX wagon most of the time the change from 1st to 2nd gear is a bit of a jolt. The other gears are very smooth. It doesnt seem to matter if its hot or cold, first start of the day or after a long drive. It doesn't seem dependant on throttle amount either. Very occasionally it shifts smoothly. Anyone had this problem or know the fix:confused: Other things I noticed that may or may not be related are Sometimes when I put the pedal to the metal at say 30km/h in second it wont change down to first and I dont have that get up and go. Also when using cruise control on the freeway lets say at 100-110km/h when a hill comes it changes to third but when the road levels out and the gearbox should go back to forth it doesn't(sometimes), I have to physically push on the accelerator then take my foot off for a couple of seconds and sort of trick it into going into forth(top gear) Apart from this around town and on the open road its usually fine. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 14, 2012 I Donated Share Posted March 14, 2012 There is no such thing as a Subaru RX. What are you talking about? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
youlikeit Posted March 14, 2012 Author Share Posted March 14, 2012 In Australia there is. All Liberty models that had the na 2.5 are called the RX at least in gen 2 & 3 Link to comment Share on other sites More sharing options...
