Aced Posted July 22, 2013 Share Posted July 22, 2013 Hi, I have an HID kit, not sure which one it is as the PO installed the setup. However, my front left bulb is dim at startup and then goes out completely after I've driven the car a few miles. Can anyone help me diagnose this problem. I'm not familiar with HID bulbs, is their a bulb that can they be replaced like halogens, or does the whole projector need to be replaced? Is being dim a sign of an electrical connection that isn't completely in contact? Thanks for your replies.. Link to comment Share on other sites More sharing options...
Zues Marine Posted July 22, 2013 Share Posted July 22, 2013 this is an HID kit: http://www.ultimatehidkits.com/images/hid-kit-large.jpg make sure you have HIDs and not just those obnoxious Xenon bulbs, although you mentioned projectors so i'm assuming you're good.. flickering can be due to a loose ground so I'd check those first... but unless it's a relatively nice or new set of HIDs, the bulb is probably getting tired just buy a PAIR of 4500K H1 HID bulbs. You can get them anywhere but this place is my fave.. even tho shipping is more than the bulbs.. http://ddmtuning.com/Products/HID-Bulb-Replacements-Pair here's a handy graphic on why not to choose gay ass HID bulbs over 5000 Kelvin!, the Y axis represents light output in lumens http://www.bolt.co.jp/images/hid_lum_003.jpg Link to comment Share on other sites More sharing options...
dshive Posted July 22, 2013 Share Posted July 22, 2013 Hi, I have an HID kit, not sure which one it is as the PO installed the setup. However, my front left bulb is dim at startup and then goes out completely after I've driven the car a few miles. Can anyone help me diagnose this problem. I'm not familiar with HID bulbs, is their a bulb that can they be replaced like halogens, or does the whole projector need to be replaced? Is being dim a sign of an electrical connection that isn't completely in contact? Thanks for your replies.. Usually if the bulb goes out after start up it's a ballast going bad. I've had a couple HID kits over the years and a cpl had that issue and it was a bad ballast. Depending on where you bought them from you can warranty or see if you can purchase a ballast by itself.. ORRR just buy a new kit lol Link to comment Share on other sites More sharing options...
snederhiser Posted July 22, 2013 Share Posted July 22, 2013 Hello; Check the underhood fuse and relay box. I believe that a bad fuse could be your problem, #24 & #26. Had this happen on an earlier legacy, dim headlight on the driver's side. Steven. Link to comment Share on other sites More sharing options...
Zues Marine Posted July 22, 2013 Share Posted July 22, 2013 another reason a bulb goes out after starting is that you dont have a large enough gauge of wire to supply the initial surge of power needed to fire the HIDs Link to comment Share on other sites More sharing options...
Aced Posted July 23, 2013 Author Share Posted July 23, 2013 Okay, I'll give these suggestions a shot. Link to comment Share on other sites More sharing options...
1Dollar93 Posted September 26, 2013 Share Posted September 26, 2013 Did you solve this problem? Link to comment Share on other sites More sharing options...
Zues Marine Posted September 26, 2013 Share Posted September 26, 2013 exposed wires Link to comment Share on other sites More sharing options...
