happhomemaker Posted February 5, 2012 Share Posted February 5, 2012 This is my second post, cant find first one:confused: I have a 99 subaru legacy gt 5mt. The clutch pedal does not come out the whole way, If you leave out fast its fine, when you drive normally the clutch only comes out about 3/4, no slippage works fine other than pedal. Replaced hose, bled and pumped up. All to no avail. Any ideas what going on? Any help would be great. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 6, 2012 Share Posted February 6, 2012 Is there a spring that helps pull it back up ? Have you looked up under the dash ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jmon4200 Posted March 29, 2012 Share Posted March 29, 2012 I had an issue similar to this in an 03 wrx that i owned. clutch would go to the floor and not come back up all the way. I just took the lid off the master cylinder and pumped the clutch and got all the air out of the system and toped off the fluid in the master cylinder. It could also be the spring in the pedal going bad. Link to comment Share on other sites More sharing options...
justflick Posted April 3, 2012 Share Posted April 3, 2012 +1 on occasionally bleeding/flushing the hydraulics. This is good practice for any car and for the brakes as well. It will keep the master and receiving cylinder in better shape longer and if you clear any bubbles while you're at it, the pedal will feel more solid with a more predictable engagement point. I'm dealing with a pedal that doesn't always return and from what I've heard, this is a possible master cylinder issue. The root of the problem is that the force from the clutch isn't strong enough to push the pedal "past the hump" of the spring down by your foot. Whether it's an adjustment or part replacement is something I'll be discovering soon enough (still haven't even run a full tank through my car yet). Link to comment Share on other sites More sharing options...
