Philsiology Posted December 12, 2012 Share Posted December 12, 2012 Hey guys, I've had my 2006 Legacy GT for about 6 months now and thinking about doing some minor mods to it. What do you guys recommend for brakes and suspension? Nothing too extreme though, I just want better handling for the streets. Link to comment Share on other sites More sharing options...
a93x Posted December 12, 2012 Share Posted December 12, 2012 dba rotors, hawk HPS pads. look in the correct sub-forum for info on the best coilovers, dont waste money on new struts springs, get some bigger sway bars w/ polyurethane bushings, new lower control arm bushings done. torque impresses girrls, hp impresses flat-bills Link to comment Share on other sites More sharing options...
Philsiology Posted December 12, 2012 Author Share Posted December 12, 2012 Thanks a lot! Link to comment Share on other sites More sharing options...
Dujo Posted December 12, 2012 Share Posted December 12, 2012 ^ Nonsense. Don't waste your money on coilovers. In order to get a decent ride, you need to get very expensive coilovers. Cheapies will likely improve the handling at the expense of a comfortable ride. Struts and springs will give you closer to the improvement you're looking for without sacrificing ride for less money than coilovers. Konis and Epics are what I run and what I recommend. Enjoy! The rest of the advice is good. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 12, 2012 Share Posted December 12, 2012 dba rotors, hawk HPS pads. look in the correct sub-forum for info on the best coilovers, dont waste money on new struts springs, get some bigger sway bars w/ polyurethane bushings, new lower control arm bushings done. Pretty much what he said. Koni inserts and Epic springs are highly recommended. check out m sprank and Mike from AZPinstalls.com for good deals. Also check out the vendor forum. I bought my Hawk pads on my 09 from Mike at AZP and the Hawk Ceramics pads on my wagon from a member on here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Drift Motion Posted December 12, 2012 Share Posted December 12, 2012 DBA rotors are very expensive HPS dusts a lot I'd just get some Centric Blanks paired with StopTech Streets, ATE SuperBlue Fluid, and maybe some SS lines as well(bitch to install) Link to comment Share on other sites More sharing options...
a93x Posted December 12, 2012 Share Posted December 12, 2012 StopTech Streets dust just as much if not more. torque impresses girrls, hp impresses flat-bills Link to comment Share on other sites More sharing options...
Philsiology Posted December 12, 2012 Author Share Posted December 12, 2012 Thanks for the feed back! But what are your thoughts on brembos? Link to comment Share on other sites More sharing options...
Dujo Posted December 12, 2012 Share Posted December 12, 2012 Brembos do not fit in the stock LGT wheels. You need larger wheels to fit a big brake kit. Lots of people run Brembos or other BBK, but general consensus is that it is overkill for these cars. Upgraded pads and rotors with the stock calipers is a nice conservative and very effective upgrade. Link to comment Share on other sites More sharing options...
Drift Motion Posted December 12, 2012 Share Posted December 12, 2012 StopTech Streets dust just as much if not more. not from what I researched, and StopTechs are cheaper... Although, I found a set of brand new HPS pads from a member here for less than the STs... Link to comment Share on other sites More sharing options...
a93x Posted December 12, 2012 Share Posted December 12, 2012 love my brembos and DBA4000 rotors. YES they are spendy, YES some may not be able to justify the expense...But i do enjoy them. I love the bite of the pads, the stopping power and how they look compared to smaller stock ones. to each his own. just depends on your budget and overall plans for the car. torque impresses girrls, hp impresses flat-bills Link to comment Share on other sites More sharing options...
a93x Posted December 12, 2012 Share Posted December 12, 2012 so your going off research and not actual use? because I have used both. YES they are cheaper. But the HPS is a better pad. They do both dust but you will find that on ant performance pad. torque impresses girrls, hp impresses flat-bills Link to comment Share on other sites More sharing options...
