idontknow Posted February 9, 2014 Share Posted February 9, 2014 I've been loosing oil and found the turbo leaking oil into the intake. Soooo, I guess I'm in the market for a new stock turbo. I've been doing some research on this and it looks like a pretty simple procedure. This car is a DD and fast enough for my taste, so I'm not really interested in aftermarket turbos for more horsepower and I would like to keep my costs down. I don't mind using used parts, but I don't know which turbo I'm looking for. I've seen a couple turbo model numbers thrown around on here but I can't figure out which turbo is on my car. Anybody know which stock turbo I need for a 06'? I plan to replace the banjo bolt filters while I'm at it, but is there anything else I should be aware of while I've got the turbo out? I still have the stock up pipe with the cat. I've read the cat can shed material into the turbo and ruin it. Should I consider replacing it to save the new turbo? Link to comment Share on other sites More sharing options...
lee07 Posted February 9, 2014 Share Posted February 9, 2014 Vf40 or vf46. No, you can leave the catted up pipe if you want. Just take out the banjo filter as people have more issues with that than the up pipe. Link to comment Share on other sites More sharing options...
idontknow Posted February 9, 2014 Author Share Posted February 9, 2014 Thanks for the answer. What's the difference between the two, if you don't mind if I ask? Link to comment Share on other sites More sharing options...
Markbo Posted February 9, 2014 Share Posted February 9, 2014 http://pretuning.com/2012/06/ihi-vf40-and-vf46-turbo-comparison/ Link to comment Share on other sites More sharing options...
Nrw Posted February 9, 2014 Share Posted February 9, 2014 2005-2006 = vf40 2007-2009 = vf46 Link to comment Share on other sites More sharing options...
TheBlackPearl Posted February 9, 2014 Share Posted February 9, 2014 I've got about 4,000 miles on my new turbo because some pieces of the OEM uppipe catalytic conveter let go and were eaten by the exhaust turbine. This was at about 128,750 miles. I scored an OEM STI non-catted uppipe for $40. I'm just sayin. Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2014 Share Posted February 9, 2014 Most will tell you the get the cat out of the up pipe. I will too. I also have both banjo filters removed from by ej257 and vf52. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jp233 Posted February 10, 2014 Share Posted February 10, 2014 I agree. get that catalytic element out of the UP as soon as possible. Since you're replacing the turbo anyways it's two more bolts to get the UP out. You can leave the EGT probe or remove it too, and do the resistor mod or have it tuned out (sounds like you're not tuned though). If you don't want to tune at all, stick with a stock turbo VF40 and be on your merry way. You could buy a new one, or potentially have your turbo rebuilt at 6 Star Speed for cheaper. Oh and absolutely, remove those banjo filters or at the least replace them if for some reason you want them. Since you're replacing the turbo anyways, why not sport for a new turbo line kit, something from say, Infamous.... then you could get the filter on the turbo line also, for better protection of the spinny thing. Between the banjo filters and the stories of people's turbo oil lines cracking (the metal ones), I'd rather have flexible oil lines for an expensive turbo. Link to comment Share on other sites More sharing options...
Markbo Posted February 10, 2014 Share Posted February 10, 2014 Words to live by. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 10, 2014 Share Posted February 10, 2014 Do we need to get into the problem with the OEM MAP and why you want your car off of it ? Go with a vf52, new oil return hose, no banjo filters, catless up pipe, with no egt probe, 3" DP and a tuned. Better mpg and safer for the valves. If it's not to late. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
