Leviathan Posted June 5, 2011 Share Posted June 5, 2011 I just flashed my '05 LGT with a 16G and the tune strongly suggests that I go with a cooler. My question is should I run the factory cooler plus the aftermarket cooler in line or just omit the factory cooler? Link to comment Share on other sites More sharing options...
ehsnils Posted June 5, 2011 Share Posted June 5, 2011 I would do an inline, first factory and then the aftermarket in order of flow. But I suspect that measuring the oil temp would really tell you if you need one or not. Link to comment Share on other sites More sharing options...
Whatisit Posted June 5, 2011 Share Posted June 5, 2011 run both factory and then aftermarket aux cooler. Also put the biggest one you can fit back there. Link to comment Share on other sites More sharing options...
Leviathan Posted June 5, 2011 Author Share Posted June 5, 2011 I ended up getting an Imperial Econo-Kool® Transmission Oil Cooler. It was $30. Not the biggest one on the planet, but it fit PERFECT. I installed it through the lower opening in the bumper on the drivers side. The supplied line was just the right amount too. I cut the longer one to fit first and the extra fit the second line. It's after the factory cooler so hopefully it can take a little more heat out of the fluid. I'll snap pictures later. Link to comment Share on other sites More sharing options...
Leviathan Posted June 5, 2011 Author Share Posted June 5, 2011 Here it is installed. http://img.photobucket.com/albums/v303/Techno_Craft/5eb95b56.jpg Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 6, 2011 Share Posted June 6, 2011 That's a pretty big trans cooler Link to comment Share on other sites More sharing options...
TheBoostNazi Posted June 7, 2011 Share Posted June 7, 2011 TRU-cool kit from autozone. $32 works great. Gunna be stuffin a FMIC infront of it this week, lol. Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 8, 2011 Share Posted June 8, 2011 TRU-cool kit from autozone. $32 works great. Gunna be stuffin a FMIC infront of it this week, lol. you mean like this? http://img62.imageshack.us/img62/8443/44055231.jpg BN, what model TruCool do you have? Link to comment Share on other sites More sharing options...
TheBoostNazi Posted June 8, 2011 Share Posted June 8, 2011 woops, not a trucool, a torqflo, lol http://www.autozone.com/autozone/parts/Compressor-Works-Transmission-Oil-Cooler/_/N-6o2r6?counter=17&filterByKeyWord=transmission+cooler&fromString=search&itemIdentifier=267252_0_0_ works flawlessly though, put on in november, still no leaks through a harsh winter EDIT: is that the racer-x fmic? I'm installing mine tomorrow or friday.... any tips on installation? Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 8, 2011 Share Posted June 8, 2011 Yeah its a RacerX. Not really, just have your dremel ready and an extra set of hands to help line up/hold pipes. Have a smaller pill or EBCS if installing w/a stock turbo. Link to comment Share on other sites More sharing options...
TheBoostNazi Posted June 8, 2011 Share Posted June 8, 2011 hmmm my tuner didn't mention anything about that Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 8, 2011 Share Posted June 8, 2011 I know I needed one with my VF40. WGDC was maxxed out and was only hitting 15 PSI. Switched to the smaller 1.00 mm pill and all was fine. Link to comment Share on other sites More sharing options...
TheBoostNazi Posted June 8, 2011 Share Posted June 8, 2011 don't know where i can find a pill.... Link to comment Share on other sites More sharing options...
frank_ster Posted June 8, 2011 Share Posted June 8, 2011 summit racing has a inline thermostat witch i think is the most important. keep oil at 180 deg .. when the oil is too cold the torque don't lock up as soon as it should.. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted June 8, 2011 Share Posted June 8, 2011 don't know where i can find a pill.... You mean you dont have any clue how to search the forum? Its only a STICKY in the tuning section. http://legacygt.com/forums/showthread.php/restrictor-pill-sizes-bleed-type-boost-control-73804.html EDIT: welcome to my "do not help kids who need to learn to search" list Link to comment Share on other sites More sharing options...
TheBoostNazi Posted June 8, 2011 Share Posted June 8, 2011 my search button went missing, couldn't search for the search button either.... Link to comment Share on other sites More sharing options...
frank_ster Posted June 8, 2011 Share Posted June 8, 2011 the factory set up is soo retarded ! , in the winter the tranny never realy gets up to temperature because the bottom of the rad is so cold. in summer it re heats the coolant after being cooled . wtf !! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
