mandayaj Posted June 7, 2011 Share Posted June 7, 2011 Where is the TCM located in a 1998 Subaru Legacy GT? Or does it not have one? Also, I installed a new transmission into my car but when I put it into drive and press gas it won't go...why is that? Is it the TCM? (my car can go into gear...just that it won't go when you press gas) Link to comment Share on other sites More sharing options...
johnegg Posted June 8, 2011 Share Posted June 8, 2011 under the dash left of the steering column. up high. it has 3 connectors on one side, they take up the whole side. plain metal color, not black. did you fully seat the torque converter before you bolted the engine to the trans?? failure to do so will damage the trans oil pump causing no go. search ''torqueconverter'' and see if you can find a how to thread. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 8, 2011 I Donated Share Posted June 8, 2011 Did you put fluid in it? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
