ard6584 Posted December 29, 2009 Share Posted December 29, 2009 Need some input....I just changed the air filter on my '06 gt wagon and immediately noticed a woosh sound coming from the engine compartment when under moderate to heavy acceleration. I have not previously noticed this sound. I used a basic Fram filter. I have double checked that everything was put back together properly but am still hearing this noise. Any chance that the Fram air filter is simply louder than the OEM filter? Link to comment Share on other sites More sharing options...
Gmoe Posted December 29, 2009 Share Posted December 29, 2009 Yep, normal. Known difference with aftermarket filters. My Avo does that too. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted December 29, 2009 Share Posted December 29, 2009 Any chance that the Fram air filter is simply louder than the OEM filter? That is very likely. I think some aftermarket paper filters have been found to flow more air than the OEM ones. Plus, your OEM filter was probably dirty by the time you replaced it, helping to muffle the sound. Link to comment Share on other sites More sharing options...
dave g Posted December 29, 2009 Share Posted December 29, 2009 Did you separate the base at the 2 alignment pins on the bottom when you took it out? I missed lining them up when I replaced my air filter and it got pretty loud. you can't easily tell that the bottom is out of line when you clip the top back together. Link to comment Share on other sites More sharing options...
king_j Posted December 29, 2009 Share Posted December 29, 2009 Yep, normal. Known difference with aftermarket filters. My Avo does that too. avo is high flow, fram should be like stock. double check everything, is it in backwards? Link to comment Share on other sites More sharing options...
peteyjr Posted December 29, 2009 Share Posted December 29, 2009 +1 avo is high flow, fram should be like stock. Double check everything, is it in backwards? Link to comment Share on other sites More sharing options...
OhBe1 Posted December 29, 2009 Share Posted December 29, 2009 +2. Even my K&N didn't make much audible difference. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
bdisco Posted December 29, 2009 Share Posted December 29, 2009 http://www.fastwrx.com/bllmdrfi.html ^Blitz makes a definite whoosh! Link to comment Share on other sites More sharing options...
Gmoe Posted December 29, 2009 Share Posted December 29, 2009 avo is high flow, fram should be like stock. double check everything, is it in backwards? Ahh... See, this is why you should never listen to me. Link to comment Share on other sites More sharing options...
ard6584 Posted December 29, 2009 Author Share Posted December 29, 2009 Thanks all...I triple checked installation making sure that the 2 bottom installation pins are in place (they are). Flat side of the filter is facing cabin with the ribbed side facing the front bumper - the way the old filter came out. I will use OEM on my next filter change. Thanks again! Link to comment Share on other sites More sharing options...
djkxgo0k Posted December 29, 2009 Share Posted December 29, 2009 call me crazy but i really like that woosh sound. =] Link to comment Share on other sites More sharing options...
zeusdog34 Posted December 31, 2009 Share Posted December 31, 2009 Thanks all...I triple checked installation making sure that the 2 bottom installation pins are in place (they are). Flat side of the filter is facing cabin with the ribbed side facing the front bumper - the way the old filter came out. I will use OEM on my next filter change. Thanks again! I think its in wrong, the ribbed side should be towards firewall...The ribbed side should be in the part of the air box closest to firewall Link to comment Share on other sites More sharing options...
king_j Posted December 31, 2009 Share Posted December 31, 2009 I think its in wrong, the ribbed side should be towards firewall...The ribbed side should be in the part of the air box closest to firewall shouldnt the ribbed side face the bumper? when i pulled out my old filter, the ribbed side is what caught all the dirt/debris/bugs. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted December 31, 2009 Share Posted December 31, 2009 I think the extra "wooosh" is the OP's butt puckering and sucking up the cockpit air due to the extra poWaR! Butt I've been wrong once before. Link to comment Share on other sites More sharing options...
stanjk3 Posted December 31, 2009 Share Posted December 31, 2009 Is it a Fram Air Hog?? AFAIK they are similar to K&N's filters. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
