matthewhiggins118 Posted April 22, 2014 Share Posted April 22, 2014 Hello my cruise is flashing just pulled my car out of storage and when i hooked battery back up cruise started flashing but no CEL. I know i reset this before but i cannot remember how to do it any help Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 22, 2014 Moderators Share Posted April 22, 2014 flashing cruise is usually a pending CEL. Best thing is probably to stop by advance (or similar) and have them pull the pending code and then reset it. Write down the pending code just in case it pops up again. If you just want to reset it you can undo the negative connection. Either leave it for a bit before reconnecting or pump the brakes for a bit and then reconnect (i think that drains the capacitors so the system will reset...?) "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
matthewhiggins118 Posted April 22, 2014 Author Share Posted April 22, 2014 The capacitors should of been completely dead the car sat for almost 6 months without the battery hooked up Link to comment Share on other sites More sharing options...
