Twyzted Posted March 10, 2014 Share Posted March 10, 2014 I installed LED park/stop bulbs in my 99 L sdn. Everything was fine until I turned on the headlights. As soon as I turned on my headlights, the ABS light came on. Did this happen because of the lack of power draw vs filament bulbs? Would adding inline resistors to the park circuit help this? When I switched the turn signals to LED I needed resistors to get them to blink correctly. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted March 11, 2014 Share Posted March 11, 2014 You are correct. You need resistors. As for the turn signals, you can buy an electronic flasher module for like $12 that replaces the stock one, and eliminates the fast-blink issue without needing to add all the resistors. Link to comment Share on other sites More sharing options...
