stephenmarr Posted November 18, 2013 Share Posted November 18, 2013 Hey guys on my 2006 2.5i wagon auto My steering wheel pulses while i turn it when im stopped It only does it when im in gear It doesn't do it when im in neutral I have replaced LCA bushes front and back Drop Links and sway bar bushes Steering rack bushes. What would the issue be. There is a little vibration when driving but i have gotten an alignment done yet. But as i said the steering wheel pulses only when im stopped and in Drive. Link to comment Share on other sites More sharing options...
ras06LGT Posted November 18, 2013 Share Posted November 18, 2013 Sounds like you might have air in the system. After turning the wheels back and forth a few times, is the fluid foamy looking? Check the fluid level and condition and report back. Link to comment Share on other sites More sharing options...
stephenmarr Posted November 18, 2013 Author Share Posted November 18, 2013 will check it tomorrow. i only recently had Subaru drain and fill the PS fluid Link to comment Share on other sites More sharing options...
ras06LGT Posted November 18, 2013 Share Posted November 18, 2013 There are a couple known problem spots for air being able to get into the system. O-ring on the top of the pump comes to mind first, as there is a recent thread discussing how to fix it. Link to comment Share on other sites More sharing options...
stephenmarr Posted November 19, 2013 Author Share Posted November 19, 2013 Yeah seen them will check my dealer to see if they have that in stock. Link to comment Share on other sites More sharing options...
