Soarin Posted February 18, 2015 Share Posted February 18, 2015 So, long story short I got the Bilstein HD upgrade kit and had a shop install everything. They didn't use the new top hat dust caps included in the kit. I put for front ones on, but I have no idea about the rear. Could they have used the dust caps off the LGT struts? What if there are no dust caps on the rear upper mounts? Link to comment Share on other sites More sharing options...
ras06LGT Posted February 18, 2015 Share Posted February 18, 2015 Because of the adjusters when I installed my Konis the stock dust caps don't fit (front or rear). I just left them off. Every once in a while I hit them with some PB blaster and move the adjuster back and forth so they don't corrode in place (mainly for the front; rears being in the car are less susceptible to corrosion) . No issues so far. Link to comment Share on other sites More sharing options...
Soarin Posted February 18, 2015 Author Share Posted February 18, 2015 Since you can reach the adjusters, is it possible for me to put on the rear dust caps? Otherwise I'm just gonna leave it til I start replacing rear bushings later this year or early next. Link to comment Share on other sites More sharing options...
ras06LGT Posted February 19, 2015 Share Posted February 19, 2015 No, the adjuster is too tall for the dust caps on both the front and rear. Link to comment Share on other sites More sharing options...
Yeti 08 Posted February 25, 2015 Share Posted February 25, 2015 The HDs don't have the adjusters that the Koni's have. So I don't think there are any dust cap fitment issues. All you have to do to look at them is pull some of the carpeting in the trunk out from behind the back seat. Pretty easy to get at. Link to comment Share on other sites More sharing options...
ras06LGT Posted February 26, 2015 Share Posted February 26, 2015 The HDs don't have the adjusters that the Koni's have. So I don't think there are any dust cap fitment issues. All you have to do to look at them is pull some of the carpeting in the trunk out from behind the back seat. Pretty easy to get at. Agreed. I was simply indicating that if there are dust cap issues for whatever reason you are fine to run without them, especially in for the rear shocks. Link to comment Share on other sites More sharing options...
Soarin Posted February 28, 2015 Author Share Posted February 28, 2015 Sorry for the late reply. I was able to check. They're in. Link to comment Share on other sites More sharing options...
