Kawasaki148 Posted February 24, 2011 Share Posted February 24, 2011 I just new hid fogs in my car and they flicker and don't light. I have hids in my headlights that work perfect, but once I put my fog hids in nothing works. The fogs flicker, light, and then go out, and my head lights just flicker and never light. I have the dtr lights pulled and this all happens while the car is parked. I know there is endless threads about this but trying to pick through them and get one solid fool proof method is a pain. Can someone help me out pleaseeee!! Thanks all Link to comment Share on other sites More sharing options...
BigTDogg MA Posted February 24, 2011 Share Posted February 24, 2011 Did you PnP the fogs? May need to do a relayed installation. Link to comment Share on other sites More sharing options...
Kawasaki148 Posted February 24, 2011 Author Share Posted February 24, 2011 Idk I'm new at this what's a pnp..or a relayed install Link to comment Share on other sites More sharing options...
Kawasaki148 Posted February 25, 2011 Author Share Posted February 25, 2011 Problem solved.!! I pulled the DRL which help a little, but seeing how my car has been parked all winter the battery was weak. I threw the charger on her curious as to if I had a bad battery and lights fired right up!! thx for anyone who PM'd sugestions Link to comment Share on other sites More sharing options...
BigTDogg MA Posted February 27, 2011 Share Posted February 27, 2011 Glad you fixed it. PNP is Plug and Play. That's where you just plug the ballasts into the headlight harness. A relayed set up would run +12VDC to the ballasts and use the headlight signal to switch the ballasts on and off. Link to comment Share on other sites More sharing options...
Kawasaki148 Posted February 28, 2011 Author Share Posted February 28, 2011 Ic Ic makes sense now, well thanks for the info and if anyone has a flicker problem make sure your battery is good!!! lol Link to comment Share on other sites More sharing options...
