LeggySue Posted November 14, 2013 Share Posted November 14, 2013 Hey guys, getting a radiator put in and was told that it would be a good idea to get the thermostat 160. apparently it has been discontinued. Does any one know where i can get one or anything that is the same thing ? Link to comment Share on other sites More sharing options...
JJr Posted November 14, 2013 Share Posted November 14, 2013 Just by OEM thermo! Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 14, 2013 Share Posted November 14, 2013 ^^^ +1 OE Thermostat-NO aftermarket Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 14, 2013 Share Posted November 14, 2013 Yea, stay oe. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2013 Share Posted November 14, 2013 OEM I believe is 180F, its what the ECU is set up for. If you cold with a colder one the car will not run correctly...unless you re-tune for it. Just get a OEM one and move on. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted November 15, 2013 Share Posted November 15, 2013 I'm running one and like it. As far as tuning, I only had to drop the fan temperatures accordingly. Everything else works fine as-is, closed loop, mileage, etc. Sad to hear it's discontinued, I'd definitely get another one if I ever had to. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Max Capacity Posted November 15, 2013 Share Posted November 15, 2013 I'm running one and like it. As far as tuning, I only had to drop the fan temperatures accordingly. Everything else works fine as-is, closed loop, mileage, etc. Sad to hear it's discontinued, I'd definitely get another one if I ever had to. How's your mpg ? How's the heater work during cold weather ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted November 15, 2013 Share Posted November 15, 2013 about 23 mpg, but not much highway involved. heater works fine - plenty hot. actual temp reported via the ecu is 167 to 174ish. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
LeggySue Posted November 15, 2013 Author Share Posted November 15, 2013 i pref dont want to go oem. I have a tuner. so re tuning would not be a problem. Link to comment Share on other sites More sharing options...
heiche Posted November 15, 2013 Share Posted November 15, 2013 i pref dont want to go oem. I have a tuner. so re tuning would not be a problem. Go for it If you find the Grimmspeed 160, please let me know, I wouldn't mind buying another to have as a spare, especially if those are going away. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
JJr Posted November 15, 2013 Share Posted November 15, 2013 about 23 mpg, but not much highway involved. heater works fine - plenty hot. actual temp reported via the ecu is 167 to 174ish. 23mpg with little HGWY, seriously hard to believe unless you only drive down hill Link to comment Share on other sites More sharing options...
JJr Posted November 15, 2013 Share Posted November 15, 2013 i pref dont want to go oem. I have a tuner. so re tuning would not be a problem. There must be a reason you can't find them, maybe they don't make them anymore because most use the OE! Link to comment Share on other sites More sharing options...
heiche Posted November 15, 2013 Share Posted November 15, 2013 23mpg with little HGWY, seriously hard to believe unless you only drive down hill That's what my car is telling me. Doesn't seem out of place to me. I do have *some* highway, but it amounts to less than around town. Here's a MPG poll for reference. Maybe that thermostat is improving my mpg? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
JJr Posted November 15, 2013 Share Posted November 15, 2013 Different thread but I get 27mpg on the HGWY @70 w/cruise but around town with hills I'm lucky to get 18mpg and I don't beat it either, well maybe I do a touch:) I guess I'm just jealous! Link to comment Share on other sites More sharing options...
iNVAR Posted November 15, 2013 Share Posted November 15, 2013 What is the purpose of running at a lower temperature? Link to comment Share on other sites More sharing options...
LeggySue Posted November 15, 2013 Author Share Posted November 15, 2013 Go for it If you find the Grimmspeed 160, please let me know, I wouldn't mind buying another to have as a spare, especially if those are going away. hey guys if anyone is looking for one , i found one gimmick motorsports has some. http://www.gimmickmotorsports.com/ Link to comment Share on other sites More sharing options...
heiche Posted November 15, 2013 Share Posted November 15, 2013 What is the purpose of running at a lower temperature? to be cool? Seriously though, googling the subject reveals a VAST argument of millions of posts on whether or not it helps/hurts knocking/mileage/oil viscosity/etc. I just figured roughly 25 degrees cooler engine might be nice. Doesn't it always seem more powerful just before the engine warms up to full operating temp? Maybe that can be partially achieved this way? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
heiche Posted November 15, 2013 Share Posted November 15, 2013 hey guys if anyone is looking for one , i found one gimmick motorsports has some. http://www.gimmickmotorsports.com/ Thanks! BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 15, 2013 Share Posted November 15, 2013 The problem I had with my aftermarket t stat, it would stay stuck open. And it took forever to warm up . I drive in the city about 15 minutes to work and had days where temps were still too low. I'm sure my oil was plenty hot but the ecu reads of coolant temp, soo I went back to oe. Mine was a mishimoto stat. I also have their radiator, so may have contributed Link to comment Share on other sites More sharing options...
iNVAR Posted November 15, 2013 Share Posted November 15, 2013 to be cool? [ATTACH]167898[/ATTACH] Seriously though, googling the subject reveals a VAST argument of millions of posts on whether or not it helps/hurts knocking/mileage/oil viscosity/etc. I just figured roughly 25 degrees cooler engine might be nice. Doesn't it always seem more powerful just before the engine warms up to full operating temp? Maybe that can be partially achieved this way?Heh, no, I've never found it be more powerful before it warms up, and if you find that to be the case, it may simply be that the intercooler is still cool as well as other intake components. Personally, I'll stick to stock temperature. The engine was designed to be operating at the higher temperature and if there were an advantage to running at a cooler temperature, I have a feeling Subaru or other car manufacturers would've caught onto that long ago. Link to comment Share on other sites More sharing options...
a93x Posted November 15, 2013 Share Posted November 15, 2013 go OEM my GS defected after 2 months. torque impresses girrls, hp impresses flat-bills Link to comment Share on other sites More sharing options...
