Rudeboy47 Posted July 26, 2014 Share Posted July 26, 2014 What's up guys, I have a 98 legacy and when driving on the free way my steering wheel starts to shake it comes and goes only when I'm going more then 60mph. I'm Wondering what it could be? Bad alignment? Tires not balanced? Bad wheel bearing possibly? Link to comment Share on other sites More sharing options...
RIRED11 Posted July 26, 2014 Share Posted July 26, 2014 I would say could be any of the above - most likely a tire out of balance - which is also pretty cheap fix. Alignment would be my next guess - also not too bad cost wise. Good luck!! Link to comment Share on other sites More sharing options...
worknlikeadog Posted July 26, 2014 Share Posted July 26, 2014 80% the bad balance on the wheels could even be a bent wheel wheel bearing is unlikely you would hear a hum before 60 mph. The easiest way to test alignment without an alignment machine is to drive about 35 miles an hour on a straight away while letting pressure off the steering wheel if it pulls really bad to one direction then alignment is likely Link to comment Share on other sites More sharing options...
TheMonaLisa Posted July 27, 2014 Share Posted July 27, 2014 Exactly same problem with my 06. Had new tires put on and developed an intermittent shake over 60. Had the dealer check the balance and they said is was all good so they don't know what the problem is. Driving me INSANE Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
johnegg Posted July 27, 2014 Share Posted July 27, 2014 if it only happens over 60, and it always happens over 60, it is probably tire balance. but a good front end shop should be able to identify the problem. Link to comment Share on other sites More sharing options...
RIRED11 Posted July 27, 2014 Share Posted July 27, 2014 Exactly same problem with my 06. Had new tires put on and developed an intermittent shake over 60. Had the dealer check the balance and they said is was all good so they don't know what the problem is. Driving me INSANE Sent from my iPhone using Tapatalk I would go to a different mechanic - it has got to be unbalanced, bad rim or maybe even a bad tire. Link to comment Share on other sites More sharing options...
johnegg Posted July 27, 2014 Share Posted July 27, 2014 i had a brand new michlen tire that would never run true. the machine said it was ok, but it always vibrated on the car at speed. Link to comment Share on other sites More sharing options...
TheMonaLisa Posted July 27, 2014 Share Posted July 27, 2014 Maybe that's what's problem is. I have brand new Goodyear Eagle F1 asymmetric tires. Problem started when I put them on. Link to comment Share on other sites More sharing options...
erickrocks1126 Posted July 28, 2014 Share Posted July 28, 2014 Same here...though mine is a bit higher and shakes/rumbling starts around 65ish. Definitely when I hit 70 its shake city. Was thinking I needed new axles...but will have to try tire alignment/balance first. Probably needs it anyway since I don't know when either have been done on the car. Link to comment Share on other sites More sharing options...
johnegg Posted July 28, 2014 Share Posted July 28, 2014 rotate one tire at a time until you ''know'' which is causing ythe problem. tire on the front, bad vibration, tire on the rear less vibration. that is the problem tire. then go back to the tire store and tell them to repeat the same test. tire on the front .... tire on the rear....... they will continue to ''adjust, balance, remount'' the tiure. but if you b1tch enough, they will give you a new different tire. Link to comment Share on other sites More sharing options...
TheMonaLisa Posted July 29, 2014 Share Posted July 29, 2014 Well was gonna start trying that test today but my front right caliper seized during an earthquake episode on the highway. Never would have guessed the caliper to fail intermittently like that. Especially cause it's only 1 year old. And I just re-greased the slides when I installed new Stoptech pads and Ccentric Premium rotors 2 months ago. Link to comment Share on other sites More sharing options...
johnegg Posted July 29, 2014 Share Posted July 29, 2014 if the caliper seized up, it may not be the tire causing the problem. i think you just got a big clue that it is a brake issue. but who knows. and if the caliper / pad has been dragging, you may have a warped rotor. what kind of grease did you use on the slide pins? Link to comment Share on other sites More sharing options...
TheMonaLisa Posted July 30, 2014 Share Posted July 30, 2014 When I installed my new rotors and pads 2 months ago I regreased the slides with real caliper grease, not a petroleum base grease. Guess is was simply a bad caliper. The rotor doesn't seem warped to me as there is no shaking under hard braking and the pad still looked like new. Will take it on the highway tomorrow for the true test. Link to comment Share on other sites More sharing options...
MrTris Posted July 30, 2014 Share Posted July 30, 2014 Steering rack bushings. Link to comment Share on other sites More sharing options...
