jmorris6689 Posted January 4, 2010 Share Posted January 4, 2010 my car stopped beeping when i lock or unlock the doors or when i pop the trunk. it stopped beeping during the snow storm we got here before christmas. anybody else ever have this problem? Link to comment Share on other sites More sharing options...
amp0412 Posted January 4, 2010 Share Posted January 4, 2010 if you look on the back of the key fob there are directions for turning the beep on and off. it is possible that this might have happened by accident. i believe they are something like hold down the lock button and unlock for five seconds or something of that nature. hope this helps Link to comment Share on other sites More sharing options...
jmorris6689 Posted January 4, 2010 Author Share Posted January 4, 2010 thanks man ill give it a shot Link to comment Share on other sites More sharing options...
jmorris6689 Posted January 5, 2010 Author Share Posted January 5, 2010 there were no instructions except how to find the car with the horn beep and how to use the panic button properly Link to comment Share on other sites More sharing options...
amp0412 Posted January 5, 2010 Share Posted January 5, 2010 Here's what is on the back of my car for "Buzzer Chirp on/off"1) Press unlock once2) Press and hold unlock AND lock buttons for two seconds. found that from someone elses post here. that should help i would confirm that for you but my keys are currently unavailable. Link to comment Share on other sites More sharing options...
jmorris6689 Posted January 5, 2010 Author Share Posted January 5, 2010 no i tried this a few times it did not work. Link to comment Share on other sites More sharing options...
scoobydoobie Posted January 5, 2010 Share Posted January 5, 2010 I disabled mine on purpose.. but I can confirm amp's procedure for turning the beep on and off. If thats not working for you not sure what the problem could be. Link to comment Share on other sites More sharing options...
MarkV Posted January 5, 2010 Share Posted January 5, 2010 my car stopped beeping when i lock or unlock the doors or when i pop the trunk. it stopped beeping during the snow storm we got here before christmas. anybody else ever have this problem? If you search a little you will find a post on this, I don't remember how to do it myself but I do remember having read the post here on LGT.com It goes along the lines of closing the door (after you get it) put the key in the ignition tunr it to the on position, then unlock the doors or something, turn the car on for a certain amount of time, turn it off then during a 10 second or so window period you have to buckle and unbuckle the drivers seatbelt... I know this sounds crazy, or stupid but honest if you find the post you will find that it does work whether or not the key less entry has the click feature programmed into it...mine didn't its titled how to " " chirp -- you can figure what the quotes can be, i forgot, sorry bud I've Crashed My ROFLChopper into a LOLCanOhttp://legacygt.com/forums/image.php?type=sigpic&userid=16939&dateline=1230531251 Link to comment Share on other sites More sharing options...
MarkV Posted January 5, 2010 Share Posted January 5, 2010 Just searche dit and found this (i believe this is what I meant ) 2009, 2008 Outback Legacy, Tribeca, Impreza Audible Chirp when locking/unlocking give you an audible signal when the doors lock and unlock. If desired, you may turn the audible signal off. Do the following to deactivate the audible signal. You can also use the same steps to restore the function. 1. Sit in the driver’s seat and shut all doors and the rear gate. 2. Hold down the UNLOCK side of the powerhttp://images.intellitxt.com/ast/adTypes/2_bing.gif door locking switch. 3. While holding down the “UNLOCK” side of the power door locking switch, pull the key out and re-insert it into the ignition switch at least 6 times within 10 seconds after Step 2. 4. Open and close the driver’s door once within 10 seconds after Step 3. 5. The turn signal lights flash 3 times to indicate completion of the setting. ***http://www.iwsti.com/forums/gr-i-c-e-security/167494-deactivate-alarm-chirp.html*** I've Crashed My ROFLChopper into a LOLCanOhttp://legacygt.com/forums/image.php?type=sigpic&userid=16939&dateline=1230531251 Link to comment Share on other sites More sharing options...
