winnipegsubaru Posted May 1, 2012 Share Posted May 1, 2012 The OEM head unit on our leagacy's support the subaru sub... this connects via the i85 connector.. now in theory could I splice on a RCA conenctor and run that to a mono block amp and run a sub off it? I tried to do a search, and everything I keep finding has to do with LOC.... This was just a thought. Thanks Link to comment Share on other sites More sharing options...
BigTDogg MA Posted May 2, 2012 Share Posted May 2, 2012 http://forums.nasioc.com/forums/showpost.php?p=9457033&postcount=4 I learned quickly, if it has to do with Subaru OEM audio, SVXdc is THE man. Link to comment Share on other sites More sharing options...
SVXdc Posted May 9, 2012 Share Posted May 9, 2012 Only certain OEM HU models have the subwoofer output. Subwoofer output (built-in 5th-channel amp) is only present on HU model P-203UE (CQ-EF1560), which was only found in 2006 Legacy spec.B and Outback VDC models. HU model P-203UH (CQ-EF1561) does not have the sub output. Follow link to that post to see pin-outs of the i85 socket. On those HUs that do have the sub out, it's amplified. You would need a 1-channel LOC (or an amp that can take a high-level signal as input). Link to comment Share on other sites More sharing options...
winnipegsubaru Posted May 10, 2012 Author Share Posted May 10, 2012 OK so if I am using a P204 head unit, the sub doesnt come out of the i85 harness, is the easiest way just to use a LOC? Link to comment Share on other sites More sharing options...
