GreenGoblin Posted September 6, 2012 Share Posted September 6, 2012 I need a front crossmember (engine cradle) for my 1997 Legacy GT automatic. I just bought the car with a busted lower control arm due to the prior owner hitting a curb. They must have hit it pretty hard because the mounting points for the lower arm and sway bar are bent about an inch from where they should be. Subarupartsforyou list a separate part number for the crossmember for GT vs all other models of the Legacy. So it seems the GT's front crossmember is constructed differently or mounts to the chassis differently. Can anyone please confirm this. I have a wrecked SUS I can get the crossmember from but it's 1hr away so I'd like to be sure beforehand. Link to comment Share on other sites More sharing options...
johnegg Posted September 6, 2012 Share Posted September 6, 2012 i would look on http://opposedforces.com/parts some times there are slight differences that will give a certain part a different number. but that does not mean you cannot use it on a different car. in the late 90s, the GT had a few suspension parts that were different from the ''L'' model like the front sway bar, but not many. the struts, hub, knuckle, tie rod end, steering rack were all the same. i doubt the cross member is different. but what ever you find, i would not buy new. i would buy from www.car-part.com .when you search for the crossmember for the 97 GT the software on that site will return results from all the car / years that will fit your car. the software is pretty conservative and if there is any doubt it will not bring up the questionable year or model. i believe the cross memeber in your car will fit any legacy / outback /GT /LSi / brighton, 95 - 99 . good luck. Link to comment Share on other sites More sharing options...
johnegg Posted September 6, 2012 Share Posted September 6, 2012 i have one from a 98 outback. and maybe a 96 lego, can't remember. let me know if you are interested. Link to comment Share on other sites More sharing options...
GreenGoblin Posted September 7, 2012 Author Share Posted September 7, 2012 The only distinction Car-Part.com made was the 2.2 vs the 2.5 engine so I guess the crossmember from my SUS donor car will fit the GT. I can't wait to get this thing resurrected! Link to comment Share on other sites More sharing options...
johnegg Posted September 7, 2012 Share Posted September 7, 2012 i saw that, and i can't figure out what the difference would be. it isn't the motor mounts or the rack mounts. oh well, glad you have one you can use. Link to comment Share on other sites More sharing options...
