wurkenman Posted July 16, 2014 Share Posted July 16, 2014 The switch itself is not that much, but that's what it cost me to get this figured out. You may recall my threads about my year long nightmare with my 05 LGT issues. Turns out no matter how small and insignificant the part may seem, there is always somehow it is connected. This little part on the very end of the transmission CAN and WILL shut down your entire automobile. It is the neutral position switch. Thanks to EricS on another forum for his suggestion, my car runs better than it has since I built it. It has been running trouble free for 3 weeks now. Actually runs and idles better than than it ever did. I got the car with a blown engine initially, so I never ran it before the build. When NF Performance tuned it, he always tried to work around some interference issues. Seems like we may have eliminated that too. Sorry about the long post. Terry http://i433.photobucket.com/albums/qq54/wurkenman/LGT/20140715_190607_zpsuyca3srw.jpg If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 16, 2014 Share Posted July 16, 2014 For those that don't know, there is a washer that goes on that switch. The washer can cause CC to drop out going down hills. I had to grind down my washer two times in the early years. It's been fine since. I haven't heard anyone complain about that issue in a very long time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted July 16, 2014 Share Posted July 16, 2014 For posterity, will you include the PN here and in the IDEAS thread? Link to comment Share on other sites More sharing options...
Redryan98 Posted July 16, 2014 Share Posted July 16, 2014 might be a dumb question but does this apply to 5MT, 5AT or both? Link to comment Share on other sites More sharing options...
FJuan Posted July 16, 2014 Share Posted July 16, 2014 That sensor should be made out of gold. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
wurkenman Posted July 16, 2014 Author Share Posted July 16, 2014 This is in a 5mt. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
700watts Posted July 16, 2014 Share Posted July 16, 2014 oh snap Link to comment Share on other sites More sharing options...
spazlamhaslam Posted July 16, 2014 Share Posted July 16, 2014 The code for this popped up on my LGT a few weeks ago along with a very fast blinking CEL, hasn't come up since but with that said, how hard is the replacement? does it cause crappy idle? What exactly does a failing switch cause? Link to comment Share on other sites More sharing options...
wurkenman Posted July 17, 2014 Author Share Posted July 17, 2014 Mine caused real high idle spikes at times. Like sitting in traffic it would fluctuate like I was just hitting the accelerator pedal repeatedly. Then it went into the spell where it just would start and die and the security light would stay on. Easy replacement. It's on the very end of the trans on the driver side. 10 minute job. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
meier motor sports Posted July 17, 2014 Share Posted July 17, 2014 my cruise control drops out more and more... how did this switch cause the car to not start? Link to comment Share on other sites More sharing options...
wurkenman Posted July 17, 2014 Author Share Posted July 17, 2014 my cruise control drops out more and more... how did this switch cause the car to not start? The car would always start, but would immediately die. This was copied from another thread on my local forum. It's about a good of an explanation as I can see. I have ran into neutral gate switches that cause idle speed control code (P1507) and cause injector cut because the PCM (engine computer) doesn't "see" the transmission in gear on closed throttle deceleration. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
lee07 Posted July 17, 2014 Share Posted July 17, 2014 Wonder if this the reason for the cruise control stumble issue? How is it at cruise control? Link to comment Share on other sites More sharing options...
wurkenman Posted July 17, 2014 Author Share Posted July 17, 2014 When it ran before and as of now cruise always worked. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
lee07 Posted July 17, 2014 Share Posted July 17, 2014 So no stumble every 1/2 mile or every few miles at 60mph? Smooth all the way? Link to comment Share on other sites More sharing options...
wurkenman Posted July 18, 2014 Author Share Posted July 18, 2014 Smooth and consistent all the way. Sometimes I have heard you might need to sand down the crush washer. I don't know why, but I've heard they cause problems. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
wurkenman Posted August 11, 2014 Author Share Posted August 11, 2014 Short lived. 7 weeks later and the problem returns. Gonna swap the drive train into an 02 wrx and party the rest. I'm tired. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 11, 2014 Share Posted August 11, 2014 Have you thinned out the washer yet ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
wurkenman Posted August 11, 2014 Author Share Posted August 11, 2014 The crush washer on the neutral switch? If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
wurkenman Posted August 11, 2014 Author Share Posted August 11, 2014 By the way it does it even with the switch unplugged. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
meier motor sports Posted August 11, 2014 Share Posted August 11, 2014 it does not make any sense that a neutral switch in a 5mt would cause the engine not to run. all it does is disable cruise control. if it was bad, depending on how it fails it would either not allow cruise or it would rev the engine when the shifter was pulled out of gear while in cruise. Link to comment Share on other sites More sharing options...
wurkenman Posted August 11, 2014 Author Share Posted August 11, 2014 Doesn't matter to me any more. I'm done with this car. Everything is getting swapped into the WRX. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
JamiSteven Posted August 11, 2014 Share Posted August 11, 2014 Doesn't matter to me any more. I'm done with this car. Everything is getting swapped into the WRX. What is swapping all the potentially faulty parts and drivetrain into a WRX going to do exactly?? Link to comment Share on other sites More sharing options...
FJuan Posted August 11, 2014 Share Posted August 11, 2014 Maybe he will find the issue then. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
wurkenman Posted August 11, 2014 Author Share Posted August 11, 2014 It's an electrical problem, not a mechanical issue. Not using the LGT electrical. I'm gonna swap heads and run a 2.5 hybrid in the WRX. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
firehawk618 Posted August 12, 2014 Share Posted August 12, 2014 it does not make any sense that a neutral switch in a 5mt would cause the engine not to run. all it does is disable cruise control. if it was bad, depending on how it fails it would either not allow cruise or it would rev the engine when the shifter was pulled out of gear while in cruise. I couldn't agree more. I haven't studied the 5mt diagrams or logic but the worst I can see it doing is disabling cruise, slight change in idle and maybe MAYBE preventing the starter from engaging. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
