BigTDogg MA Posted March 13, 2013 Share Posted March 13, 2013 I've been all over http://www.ae64.com and through numerous searches here, but have not found the answer. What is the pinout of the 86257AG100 factory AUX jack? I'll email SVXdc if I have to, but I figured the info would help other people as well. Thanks T Link to comment Share on other sites More sharing options...
KCwagon Posted March 13, 2013 Share Posted March 13, 2013 I normall don't use awesome and Nasioc in the same sentence but check this thread out. It is great for pin-out information as well as good links for builds. http://forums.nasioc.com/forums/showthread.php?t=749402 Link to comment Share on other sites More sharing options...
BigTDogg MA Posted March 14, 2013 Author Share Posted March 14, 2013 Thanks, I think I got close enough in this thread: http://legacygt.com/forums/showthread.php/installed-aux-port-2005-outback-long-149614.html I'll check the 2007 wiring diagram when I get a chance. Link to comment Share on other sites More sharing options...
AkumaMax Posted March 14, 2013 Share Posted March 14, 2013 From what I remember it is a 6 pin connector. Pins: 1 - Yellow 2 - Green Yellow 3 - Brown 4 - NOT USED 5 - Red White 6 - Black Link to comment Share on other sites More sharing options...
BigTDogg MA Posted March 14, 2013 Author Share Posted March 14, 2013 From what I remember it is a 6 pin connector. Pins: 1 - Yellow 2 - Green Yellow 3 - Brown 4 - NOT USED 5 - Red White 6 - Black It is, thanks! And I believe the audio goes 1-right 2-common 3-left This whole thread was kinda stupid, as I was bored sitting at my desk at work thinking about how to wire everything up. Took me 20 seconds once I got home to look at a SVXdc I85 cable and the I85 plug I cut from the junkyard donor to match stuff up. I'll post details later. Link to comment Share on other sites More sharing options...
AkumaMax Posted March 15, 2013 Share Posted March 15, 2013 I think 5 is actually one of the Audios. I know when I was wiring my Navigation to fit my 05 the Green/Yellow was ACC POWER. Pretty sure this is to supply the lines power to recognize the line going to the unit. I know what you mean about the plug they are pretty much plug and play stuff. Not hard at all. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted March 15, 2013 Author Share Posted March 15, 2013 I think 5 is actually one of the Audios. I know when I was wiring my Navigation to fit my 05 the Green/Yellow was ACC POWER. Pretty sure this is to supply the lines power to recognize the line going to the unit. I know what you mean about the plug they are pretty much plug and play stuff. Not hard at all. 99% sure I got the audio section right, at least for the 2007 model. I snipped the chassis side harness from the junker and it has what appears to be L and R with a common in the middle. The common is tied to the shielding in the harness. The position of the colors coordinates with the I85 harness as well. I'll snap some pics tonight while I'm working on it. Gotta email David anyway to verify other connections. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted March 18, 2013 Author Share Posted March 18, 2013 So I was spot on with the pinout. From David (SVXdc): 1 YELLOW - Audio Right 2 GRAY/YELLOW - Audio ground/shield 3 BROWN - Audio Left 4 NC - (aux pod's PC board ties this to pin 2 ground) 5 RED/WHITE - Aux enable switch 6 BLACK - Aux enable switch The 5 and 6 pins can be clipped and capped. They can be shorted to each other, but there's no need if you have a SVXdc i85 harness, as his harness grounds with the fork terminal. The Aux bucket also shorts audio ground to signal left and right, so if you want to tap in another AUX source, you either need to modify the AUX bucket board or add it on the outside (plug in to jack with adapter, not hardwired). Dave's been EXTREMELY helpful before and after the sale of his harnesses. Definitely recommend using him for any Subaru audio harness needs. Link to comment Share on other sites More sharing options...
