nads Posted February 15, 2017 Share Posted February 15, 2017 So after rain (washing the car) I get water settling on the drivers side strut tower (mainly that side because of the way the car sits in my drive way). Is this normal? I had the windshield replaced in the early fall of 2016 but recall it doing it before that. Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 15, 2017 Share Posted February 15, 2017 Take it to the dealer. You need a new hood seal to keep that water out. They are the only ones who can install the part. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
GTEASER Posted February 15, 2017 Share Posted February 15, 2017 It's fine. No need to worry. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
FJuan Posted February 15, 2017 Share Posted February 15, 2017 Dat rust though. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
derp Posted February 15, 2017 Share Posted February 15, 2017 I don't even understand the question. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
nads Posted February 15, 2017 Author Share Posted February 15, 2017 I don't even understand the question. Is this directed at my post? Link to comment Share on other sites More sharing options...
FJuan Posted February 15, 2017 Share Posted February 15, 2017 I don't even understand the question. Do you even understand life? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
derp Posted February 15, 2017 Share Posted February 15, 2017 Is this directed at my post? yeah, I can't picture how water would pool at the strut tower, unless your gen is that different from an 4th gen I could suck start a snow blower. Link to comment Share on other sites More sharing options...
gkinslow Posted February 15, 2017 Share Posted February 15, 2017 I definitely don't understand life. Link to comment Share on other sites More sharing options...
FJuan Posted February 15, 2017 Share Posted February 15, 2017 yeah, I can't picture how water would pool at the strut tower, unless your gen is that different from an 4th gen Here derp, I drew you a picture. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 16, 2017 Share Posted February 16, 2017 also check to make sure the hood is flush.... if it is not sealing properly that could be it. Link to comment Share on other sites More sharing options...
islandborn Posted February 16, 2017 Share Posted February 16, 2017 Would a drain hole help? Maybe a small bit Fjuan - just enough to let the pooling dribble out? Link to comment Share on other sites More sharing options...
gkinslow Posted February 16, 2017 Share Posted February 16, 2017 Air follows water. Multiple holes will be necessary for proper drainage. Link to comment Share on other sites More sharing options...
Humble Rumble Posted February 16, 2017 Share Posted February 16, 2017 Multiple holes will be necessary for proper drainage. Paging FJuan. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
BBPeik Posted February 16, 2017 Share Posted February 16, 2017 This should fix it My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
nads Posted February 16, 2017 Author Share Posted February 16, 2017 ^^Does it come in 1 gallon pails? I'll just slop that on and let it ride! Link to comment Share on other sites More sharing options...
FJuan Posted February 16, 2017 Share Posted February 16, 2017 Air follows water. Multiple holes will be necessary for proper drainage. Paging FJuan. Page received, bringing the van around. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
cww516 Posted February 16, 2017 Share Posted February 16, 2017 Probably got gallon jugs of something in there... Link to comment Share on other sites More sharing options...
FJuan Posted February 17, 2017 Share Posted February 17, 2017 Probably got gallon jugs of something in there... Lube, gallons of lube. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Redbone Posted March 16, 2017 Share Posted March 16, 2017 I have 2010 Legacy Ltd with just over 100K km's (60,000 miles) with the same issue on the passenger side. I've also developed a rust ring. Recently replaced the noisy strut on that side also. Contacted Subaru of Mississauga and spoke to the service manager who stated that they are not aware of any issue. He (Robert) suggested at looking at the cowling seal and the wheel well liner to make sure it's not open allowing water to be splashed up. F.Y.I. my vehicle has not been in an accident prior. I can't see how a cowling seal would wear or how a wheel well liner would be misaligned but will check for gaps. Link to comment Share on other sites More sharing options...
nads Posted March 16, 2017 Author Share Posted March 16, 2017 I have 2010 Legacy Ltd with just over 100K km's (60,000 miles) with the same issue on the passenger side. I've also developed a rust ring. Recently replaced the noisy strut on that side also. Contacted Subaru of Mississauga and spoke to the service manager who stated that they are not aware of any issue. He (Robert) suggested at looking at the cowling seal and the wheel well liner to make sure it's not open allowing water to be splashed up. F.Y.I. my vehicle has not been in an accident prior. I can't see how a cowling seal would wear or how a wheel well liner would be misaligned but will check for gaps. Have you had your windshield replaced? I did late last summer and I think the ends seals cause the leak. Like they weren't installed correctly or your supposed to use a sealant. Link to comment Share on other sites More sharing options...
derp Posted March 16, 2017 Share Posted March 16, 2017 Page received, bringing the van around. vroom vroom! *tire screech* I could suck start a snow blower. Link to comment Share on other sites More sharing options...
Redbone Posted March 16, 2017 Share Posted March 16, 2017 Have you had your windshield replaced? I did late last summer and I think the ends seals cause the leak. Like they weren't installed correctly or your supposed to use a sealant. No, the windshield is original. Good thinking though. Link to comment Share on other sites More sharing options...
nads Posted March 17, 2017 Author Share Posted March 17, 2017 Well it wasn't pouring out side so I got some time to look at what could cause this. The two end seals (passenger and driver side) are not sealing against the glass and were deformed. I can see a direct path from them to the strut tower. They locate by two pins on the center cowl cover and wedge against the fender and glass in the corners. I ordered two new ones. Will up date when I install them Link to comment Share on other sites More sharing options...
