Funkyman831 Posted July 8, 2013 Share Posted July 8, 2013 Hey guys I have had the dreaded crickets from my TOB fresh out of a new clutch install. I have tried adjusting my pedal as well as putting a return spring on. None have worked unfortunately. The return spring pulls the fork back a tad bit, but in doing this there is a huge deadzone within the pedal. There is also a small deadzone towards the top of the pedal that i can push in and I have to pull it out. I am starting to think I have a bad Clutch slave cylinder that is putting pressure on the fork giving me these issues. I also had my clutch pedal stick to the floor last night when I gave it a hard take off. I am posting this here to see if anyone else has had this issue as well. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 8, 2013 Share Posted July 8, 2013 What brand clutch ? Did you install a new TOB ? You could have a bad (new) TOB, nothing is perfect every time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Funkyman831 Posted July 8, 2013 Author Share Posted July 8, 2013 Exedy OEM clutch/PP, ACT LWFW, and TSK-3 TOB. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 8, 2013 Moderators Share Posted July 8, 2013 Clutch pedal stuck to the floor? Re-bleed the cylinder and the slave. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Funkyman831 Posted July 8, 2013 Author Share Posted July 8, 2013 We bled from the slave cylinder yesterday... it didn't really do much. Do we also need to bleed from the master? I assumed it would all end up going through the slave. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 8, 2013 Moderators Share Posted July 8, 2013 We bled from the slave cylinder yesterday... it didn't really do much. Do we also need to bleed from the master? I assumed it would all end up going through the slave. I had to rebleed due to a leak, so YMMV, but yes--a massive amount of air came out of both the slave and the master. We had the best results doing one bleed process on the master, then the slave, then back to the master, then the slave, etc. until no more air. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Funkyman831 Posted July 8, 2013 Author Share Posted July 8, 2013 About how many times did you open/close the nipples on each cylinder process? I'd say we did the slave about 6-7 times until we didn't see the old fluid in the master cylinder container. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 8, 2013 Moderators Share Posted July 8, 2013 We did the master a few times with the pedal still getting stuck at the floor before moving over to the slave. Then I'd say we did the slave/master swap a couple more times and it was all good. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Funkyman831 Posted July 8, 2013 Author Share Posted July 8, 2013 Okay I will try this again, but if it doesn't work I can assume my slave cylinder is going kaput. I don't think I mentioned this, but the slave cylinder does make a squeaking noise at full depression. I'm just confused as to why this issue only comes up after a new install of the clutch kit. Link to comment Share on other sites More sharing options...
