subiegillis Posted October 31, 2012 Share Posted October 31, 2012 okay i have a 2005 LGT i have been lookin at buying parts to go stage 3 in about feb. so i have been lookin at up pipes and can't really tell any difference if there is. the three i have been lookin at are just the stock 07 LGT up pipe, the grimmspeed coated uppipe and the AMR cast iron up pipe . i know people are goin to say well there is a price difference not really worried about that . i am curious if there is goin to be drastice power difference between the three .. for the turbos i am lookin at are the bnr 18g and 20g not sure which one yet still thinkin:spin: Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 31, 2012 Moderators Share Posted October 31, 2012 there won't be a power difference between the three. the only thing that would necessarily help AFAIK is to have things ported and polished to make things match up perfectly (headers to up pipe, up pipe to turbo, .....) "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Boston Motorsports Posted October 31, 2012 Share Posted October 31, 2012 Look into the Cobb Tuning 2 inch up pipe, great piece! Link to comment Share on other sites More sharing options...
ChemicalWaste Posted October 31, 2012 Share Posted October 31, 2012 Look for stock STI or 07 or newer. They can be had for cheaper than cobb. You won't see a huge difference in power for a while unless your stage 3 = big f-ing turbo, which 18g and 20g don't fit the bill. Larger diameter = slower spool, more top end, in theory. Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted October 31, 2012 Share Posted October 31, 2012 ^ Yep. I picked up a '05 STI UP for mine and it has been good for the past 2.5 years. Link to comment Share on other sites More sharing options...
06legsleeper Posted October 31, 2012 Share Posted October 31, 2012 same i just got a 06 sti up pipe , getting in put in shortly soon as the weather clears a bit Link to comment Share on other sites More sharing options...
ChemicalWaste Posted October 31, 2012 Share Posted October 31, 2012 Mine was from an 05 if i remember correctly. Haven't had an issue yet. Link to comment Share on other sites More sharing options...
Nrw Posted November 1, 2012 Share Posted November 1, 2012 I love my grimmspeed ceramic coated up-pipe. Craftsmanship in it is top notch. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted November 1, 2012 Share Posted November 1, 2012 AG - If you really want my input it would be much more meaningful for us to discuss your goal and then mod path. I have no way to tell you which uppipe without knowing your goal. WHY? I'm quite happy with my three flange up / header GTSPEC / Tomei style (mine is gtspec). It has a super sexy velocity stack inside (something the others dont have to my knowledge) and is not going to leak. Whats my point? If you tell me what you want I can help point you in the direction of a likely mod list you should research. Otherwise I'm just posting up about parts. Parts is parts. Link to comment Share on other sites More sharing options...
fahr_side Posted November 1, 2012 Share Posted November 1, 2012 If you're sure you're going to keep the stock manifolds, get an OEM catless up-pipe. If you're looking to get the full potential from your 18G, buy an equal-length header that comes with an up-pipe. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 1, 2012 Share Posted November 1, 2012 I have a Invidia catless up pipe and down pipe, I got them from my Tuner, http://legacygt.com/forums/forumdisplay.php/tuning-alliance-121.html When it comes time for the swap, pick up the bolts from the dealership that hold the up pipe bracket to the engine block. use them to bolt the turbo to the up pipe, 10x easier then trying to install the turbo on the up pipe, inlet and oil return at the same time with the studs in there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
subiegillis Posted October 6, 2013 Author Share Posted October 6, 2013 Okay someone had said I can use an sti up pipe....what year do I need.. I just got a VF52 Sent from my SPH-L710 using Tapatalk 4 Link to comment Share on other sites More sharing options...
PtPixel Posted October 6, 2013 Share Posted October 6, 2013 08+ will fit - they are the wrx's with the VF52s stock Link to comment Share on other sites More sharing options...
subiegillis Posted October 6, 2013 Author Share Posted October 6, 2013 Will a 06-07 sti uppipe work??? My buddy has one Sent from my SPH-L710 using Tapatalk 4 Link to comment Share on other sites More sharing options...
PtPixel Posted October 6, 2013 Share Posted October 6, 2013 Think it might... 06-07 sti is the VF39 which I think has the same flange connections as VF52 Link to comment Share on other sites More sharing options...
Brian3676 Posted October 6, 2013 Share Posted October 6, 2013 I have Grimmspeed. Fits nice Link to comment Share on other sites More sharing options...
subiegillis Posted October 7, 2013 Author Share Posted October 7, 2013 Well chemicalwaste and others have said an sti one will work but I want to make sure I get the right one from the sti Sent from my SPH-L710 using Tapatalk 4 Link to comment Share on other sites More sharing options...
PtPixel Posted October 7, 2013 Share Posted October 7, 2013 From what I understand the VF39, VF48 and VF52 are all basically the same turbo, just newer revisions of each other. So long as the turbo it has come off of is one of them then you should be fine. Link to comment Share on other sites More sharing options...
HarryD Posted October 12, 2013 Share Posted October 12, 2013 An up-pipe from any STi will work (2004 +). They all fit the same and none of them have the Catalytic Converter. Link to comment Share on other sites More sharing options...
