nuked_oasys Posted April 15, 2015 Share Posted April 15, 2015 So, I'm working through a timing belt change (following the thread in the Maintenance sub), and the damn vice grips slipped off the drivers side cam gears. Both cams turned, but I have no idea which direction they turned. What can I do to get them back in time? I know they turn at half the speed of the crank, so do I need to rotate them both clockwise twice? Or do I just get them lined up, turn the crank by hand and hope for the best? Help! Link to comment Share on other sites More sharing options...
CloudSeed777 Posted April 15, 2015 Share Posted April 15, 2015 I would proceed carefully. You need to figure out if the valves are hung up on eachother or if both sets went back to "closed" (or seated) position. I'm assuming your CRANK was at TDC? If you were at TDC the valves would not interfere with pistons. Is the engine in the car or on a stand? Link to comment Share on other sites More sharing options...
nuked_oasys Posted April 15, 2015 Author Share Posted April 15, 2015 The crank was at TDC yes, I already had the belt off,sp the timing marks were lines up. The motor is in the car. I don't think the valves are hung up on each other. I turned each cam slightly until I felt pressure, and didn't hear anything release. Link to comment Share on other sites More sharing options...
CloudSeed777 Posted April 15, 2015 Share Posted April 15, 2015 The crank was at TDC yes, I already had the belt off,sp the timing marks were lines up. The motor is in the car. I don't think the valves are hung up on each other. I turned each cam slightly until I felt pressure, and didn't hear anything release. You should be good to go then. Just start over. Link to comment Share on other sites More sharing options...
nuked_oasys Posted April 15, 2015 Author Share Posted April 15, 2015 Ok. I rotated each cam through by hand into position, and didn't feel anything bind or any severe pressure. I'll be triple checking the timing marks for sure. Is there anything extra I can do when turning the crank through by hand? Just being cautious. Thanks! Link to comment Share on other sites More sharing options...
CloudSeed777 Posted April 15, 2015 Share Posted April 15, 2015 When I did mine, I turned the pulleys with a wrench (I don't think you can hand turn them without it being pretty awkward) then used the belt to hold the intake pulley in position while I did the exhaust. I followed this vid when I did mine: Link to comment Share on other sites More sharing options...
CloudSeed777 Posted April 15, 2015 Share Posted April 15, 2015 Also, with the engine in the car, use a small hand mirror to check your marks. Link to comment Share on other sites More sharing options...
nuked_oasys Posted April 15, 2015 Author Share Posted April 15, 2015 Got everything lined up and cranked over, looks good so far. Didn't feel anything bind while I was cranking it. Should be in good shape. Thanks for the help! Link to comment Share on other sites More sharing options...
starionesir Posted April 15, 2015 Share Posted April 15, 2015 Just for your info next time. You really should not use vice grips on any timing belt. I've seen more then a couple guys damage a belt that way. Best thing I have found for cheap is the clips they make for stuff like potato chip bags. More then strong enough to hold the belt on but won't damage it. Link to comment Share on other sites More sharing options...
CloudSeed777 Posted April 15, 2015 Share Posted April 15, 2015 Just for your info next time. You really should not use vice grips on any timing belt. I've seen more then a couple guys damage a belt that way. Best thing I have found for cheap is the clips they make for stuff like potato chip bags. More then strong enough to hold the belt on but won't damage it. I'd bet he wasn't using the vice-grips to hold the belt, but using them to hold the intake/exhaust cams at their marks by clamping the pulleys together, another big no-no IMO. You can brake the bake-light pulleys pretty easily doing this. Link to comment Share on other sites More sharing options...
nuked_oasys Posted April 15, 2015 Author Share Posted April 15, 2015 You're correct, the grips were on the pulleys. Although I did have a piece of wood in between to reduce stress on the pulleys. Probably not the best idea anyway, but it's what I had. Link to comment Share on other sites More sharing options...
Enlight Posted May 4, 2015 Share Posted May 4, 2015 Hey guys, I'm also in the middle of a timing belt job and have run into a variation on this problem. I was taking the timing belt off without the cam-lock tool, not knowing that the valve springs would turn the cam shafts (driver side). I was startled by this and released the belt from my hands when it engaged the cam again and I believe kept the valves from seating back all the way. This is the current state that it's in. The crank was TDC when this happened and the car is on stands. How am I supposed to proceed? I feel like I'm missing something because page ME(H4DOTC)-42 in the manual simply says to remove the timing belt after removing the bottom idler pulley - no mention of a cam lock tool. What are the positions of the driver side valves when the crank is at TDC? muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
nuked_oasys Posted May 4, 2015 Author Share Posted May 4, 2015 You will probably be ok. You'll need to turn each cam clockwise until the match marks line up. I turned them by hand, you could also use a wrench. Turn them very slowly and very carefully. Start with the top. If they both turn free at first, you're OK. You can turn each cam through a complete cycle without damaging anything. Don't let them spin counter clockwise! You'll need to secure them in place once they're rotated to where you want them. I'd use the old belt, or use a bolt and nut to keep the gears together. There's a walk through in the maintenance section. Hope that helps! Link to comment Share on other sites More sharing options...
Enlight Posted May 4, 2015 Share Posted May 4, 2015 Ok, I didn't know that it was normal for the driver side cams to move after the belt is removed. Link muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
nuked_oasys Posted May 4, 2015 Author Share Posted May 4, 2015 Yes, the drivers side cams are on when the crank is at TDC. Just turn them to where they need to be and carry on. Good luck! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 5, 2015 Share Posted May 5, 2015 Just for the record .. When a timing belt is changed, the pistons are not at TDC. TDC means 'top dead center', which means that the pistons are very close to the valves. Instead, when timing belts are changed, the pistons are half way in so as to avoid contact with the valves. Link to comment Share on other sites More sharing options...
nuked_oasys Posted May 5, 2015 Author Share Posted May 5, 2015 Thanks for the clarification. I was using the notch on the crank pulley as a TDC indicator, but you're right it's not TDC in the technical sense. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 5, 2015 Share Posted May 5, 2015 No worries. IIRC, there are two marks on the crank sprocket, a short notch at the back of it, and an arrow at the front of it. TDC is associated with the arrow. The notch is used for timing belt change. Link to comment Share on other sites More sharing options...
