hawker800mech Posted July 14, 2013 Share Posted July 14, 2013 It appears that mine is leaking oil on my 06 wagon. Does that make sense? Link to comment Share on other sites More sharing options...
bomberlegacy Posted July 14, 2013 Share Posted July 14, 2013 Photo? '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
hawker800mech Posted July 14, 2013 Author Share Posted July 14, 2013 This photo is not mine but it is the same. The plug with Allen key hole next to filter. http://i42.photobucket.com/albums/e311/hawker800mech/dsc00742w_zpscaf46c74.jpg Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 15, 2013 Share Posted July 15, 2013 That is the freeze plug if you add the optional block heater accessory that is were it would screw in to heat the coolant. If there is oil there it may be coming from the pan or filter. Link to comment Share on other sites More sharing options...
hawker800mech Posted July 15, 2013 Author Share Posted July 15, 2013 Shoot, I thought I had found it. I have changed the oil filter two times with different brands and it still leaks the same. Will have to look closer at the oil pan. Thanks for the info. Link to comment Share on other sites More sharing options...
Jay12Legacy Posted August 2, 2013 Share Posted August 2, 2013 Do you have a oil cooler I see them seep all the time and also make sure it's oil I have also see power steering pump leak make it behind the timing covers and then drip off the oil filter Jay Link to comment Share on other sites More sharing options...
hawker800mech Posted August 2, 2013 Author Share Posted August 2, 2013 I'll take a look around thanks. Link to comment Share on other sites More sharing options...
hawker800mech Posted August 25, 2013 Author Share Posted August 25, 2013 Well, if anyone is interested, I found the oil pan bolt next to that plug a little loose and got about a flat turned on it. Haven't verified if the leak is gone yet. Keeping my fingers crossed. Link to comment Share on other sites More sharing options...
