kurtis9813 Posted November 14, 2014 Share Posted November 14, 2014 97 legacy gt sedan. Electronic door switch locks/unlocks all doors but driver door..... Locked and unlocked driver door by hand like 10 times but will not lock/unlock with others when i hit the switch. Also i unplugged the keyless entry unit last week because it started locking/unlocking doors on its own randomly and was setting off the car alarm. Link to comment Share on other sites More sharing options...
johnegg Posted November 14, 2014 Share Posted November 14, 2014 Also i unplugged the keyless entry unit last week which came first, unplgged remote entry unit or driver door will not lock with electronic button. i think there is a situation where the electric lock fails to work the drive door due to a linkage issue. oep the door panel and trace all the metal linkage. and i suspect unplugging the remote entry unit will eliminate the driver door from the electric lock system. these sound a little conflicting, but who knows. Link to comment Share on other sites More sharing options...
kurtis9813 Posted November 17, 2014 Author Share Posted November 17, 2014 I'll try plugging the keyless entry unit back in and if that doesnt work i'll open up the door panel Link to comment Share on other sites More sharing options...
twisty Posted November 21, 2014 Share Posted November 21, 2014 could be a bad actuator Link to comment Share on other sites More sharing options...
kurtis9813 Posted December 1, 2014 Author Share Posted December 1, 2014 plugged the keyless entry module back in and the electronic lock works again. keyless entry unit started blinking the flashers when i plugged it back in, which is why I unplugged it in the first place, but I found that plugging in one plug allows me to lock and unlock the door with the switch but keeping the other plug out keeps the keyless entry unit from causing the alarm(blinking flashers) to go off. Going to try installing a different keyless entry unit tomorrow and see if it fixes the alarm problem. Link to comment Share on other sites More sharing options...
johnegg Posted December 1, 2014 Share Posted December 1, 2014 try plugging in the keyless unit with the key in the run position, key on, engine off. when power is applied to the remote entry unit, it thinks you are stealing the car unless you have the key in the run position. good luck. Link to comment Share on other sites More sharing options...
kurtis9813 Posted December 2, 2014 Author Share Posted December 2, 2014 just tried plugging it in with the key on. didnt help. I pretty sure this module is shot because it was also locking and unlocking doors on its own Link to comment Share on other sites More sharing options...
johnegg Posted December 3, 2014 Share Posted December 3, 2014 ok, if it is a suabru unit, a replacement will plug right in. if aftermarket, who knows. place a wanted ad in the classifieds. i may have one, but it will take me a while to find it, if i do. i have never heard of one going bad. or just live with no remote entry. Link to comment Share on other sites More sharing options...
kurtis9813 Posted December 3, 2014 Author Share Posted December 3, 2014 The unit is stock and i have an extra one lying around somewhere, just gotta go on a hunt to find where i put it. Link to comment Share on other sites More sharing options...
kurtis9813 Posted December 4, 2014 Author Share Posted December 4, 2014 Installed the other module today. No more alarm or self locking/unlocking doors. My guess the old unit had some dust or corrosion build up on the inside and was causing electricity to bridge where it shouldn't. Not an expert on electronics though. Link to comment Share on other sites More sharing options...
johnegg Posted December 5, 2014 Share Posted December 5, 2014 congrats! glad you solved it. now you need a remote to operate it.?? Link to comment Share on other sites More sharing options...
kurtis9813 Posted December 5, 2014 Author Share Posted December 5, 2014 Already have 2 remotes. And fyi for anyone looking for remotes ive found a few at junkyards that let you pick and pull from the yard. Just find a remote from one of the cars and add it to your keychain. Lol. Or pay for it if you like. Link to comment Share on other sites More sharing options...
