LegacyTX Posted April 29, 2012 Share Posted April 29, 2012 I have an interesting problem. I recently purchased my first Subaru (2008 legacy SE) 30k miles. After having the car a few days I began noticing some issues with the instrument cluster. The blue temperature indicator light stays on and the Si drive display flashes the . After some research I have discovered that the car has the GT version of the instrument cluster. My car is not a GT and does not have Si drive. It should not have this cluster. My guess is the previous owner removed the original instrument cluster and installed the 2008 GT cluster. I have a few questions. 1. Could this affect performance of the car? Performance seems perfect right now. 2. If I wanted to put the original instrument cluster (style) back in, would i have to have it reprogrammed? What would happen with the odometer? Thanks for any help you can provide. Link to comment Share on other sites More sharing options...
RabidWombat Posted April 29, 2012 Share Posted April 29, 2012 Why would someone replace the instrument cluster with a GT cluster? There's something really fishy about that. Are you sure the car has a completely clean title? Link to comment Share on other sites More sharing options...
LegacyTX Posted April 29, 2012 Author Share Posted April 29, 2012 Dealership (which is very reputable) confirms the title is clean. As well as car fax. It has me stumped as well. Is is possible that they preferred the looks of the GT cluster? Has that come up before? Link to comment Share on other sites More sharing options...
sahrbjr Posted May 1, 2012 Share Posted May 1, 2012 Someone in the parts department probably messed up when ordering the cluster for your car. Check to see where the cluster was replaced. If it was replaced by the original owner which I doubt then they may have done something sketchy. If it were by the dealer then the mileage is probably right but the cluster was ordered incorrectly most likely and they should replace for you free of charge. As far as performance their is no issue. It will most likely have to be reprogrammed. Those lights are on and illuminating as a default because there are no input signals being that your car isnt equipped with those systems Link to comment Share on other sites More sharing options...
laz Posted May 1, 2012 Share Posted May 1, 2012 Post a picture as to what your cluster looks like. It would be very easy to decipher what cluster you have. X --- Link to comment Share on other sites More sharing options...
LegacyTX Posted May 1, 2012 Author Share Posted May 1, 2012 I will post a picture. Sahr..., you are spot on with your post. After some digging, I have discovered that the part was ordered and put in the car by the dealership just prior to when I bought the car. They have offerred to correct the problem. However, I am not sure I want the original cluster, I like some of the upgraded features on this cluster. As long as it is programmed correctly (which they have assured me it is), do any of you experts see any issues with keeping it? Thanks Link to comment Share on other sites More sharing options...
laz Posted May 1, 2012 Share Posted May 1, 2012 If you don't mind the lights being on all the time. It may also be an issue if you ever sell the car to a private party or try to trade it in. If you keep it make suer that you have a record from the dealership as being replaced. GL X --- Link to comment Share on other sites More sharing options...
Leviman Posted May 1, 2012 Share Posted May 1, 2012 Just go into the cluster and pull the si drive bulbs, no more light! Haha Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 2, 2012 Share Posted May 2, 2012 Just go into the cluster and pull the si drive bulbs, no more light! Haha I believe there are only LEDs in there. Link to comment Share on other sites More sharing options...
dsickles Posted May 2, 2012 Share Posted May 2, 2012 yea, SI drive only shows up in the LCD display Link to comment Share on other sites More sharing options...
Leviman Posted May 2, 2012 Share Posted May 2, 2012 I believe there are only LEDs in there. Then desolder them? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 3, 2012 Share Posted May 3, 2012 Then desolder them? yeah I was going to mention that as well but I am not sure if another led would turn on to let you know of some kind of malfunction . Not like the old days anymore.. Link to comment Share on other sites More sharing options...
LegacyTX Posted May 3, 2012 Author Share Posted May 3, 2012 I have had the car a few weeks and hardly notice the light (blue light) anymore. At this point I am not inclined to disassemble the dash and take out the cluster. If it gets to a point to where I can not longer handle the light, I will have the original cluster put in. I got the dealership to go ahead and order the part for me and they will give it to me. If I want it put in, they will do it for free. Thanks for all of the tips and advice. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 3, 2012 Share Posted May 3, 2012 fyi, if it is similar to the 05s, the cluster is very easy to take off. Maybe 4-5 screws max. Link to comment Share on other sites More sharing options...
cseagle08 Posted May 3, 2012 Share Posted May 3, 2012 I don't think you have to worry about the odometer - that information should come from the computer itself. I know on at least a late 90's+ GM cars you can swap them and the new cluster will automatically update itself with the correct mileage once you turn it on. Even with an analog odometer. Surely Subaru's do a similar thing. Link to comment Share on other sites More sharing options...
OGHK87Jay Posted May 5, 2012 Share Posted May 5, 2012 Hey LegacyTX when you swap it back to regular gauges can I have the gt guages? PM me please. Question for you guys does the subaru dealer do the reprogramming of the milage or is it the dmv or something. Because I heard different stories from 2 different subaru dealers Link to comment Share on other sites More sharing options...
OGHK87Jay Posted May 5, 2012 Share Posted May 5, 2012 Then desolder them? then the mileage guage doesnt work haha Link to comment Share on other sites More sharing options...
OGHK87Jay Posted May 5, 2012 Share Posted May 5, 2012 fyi, if it is similar to the 05s, the cluster is very easy to take off. Maybe 4-5 screws max. I just did mine on my car and it is not similar to the 05s its actaully 7-8 screws (it was liek 5 for the guages and 3 for the cluster glass) and very hard to take out it took me 1 hour mainly because some of them screws are really hard to get to. So many things to remove and I basically had to open and remove some parts on the steering column. i still have one screw out and have no idea where that one goes back into. Link to comment Share on other sites More sharing options...
Leviman Posted May 5, 2012 Share Posted May 5, 2012 then the mileage guage doesnt work haha Well he said they were LEDs so I imagined light bulbs. Turns out its in the LCD. LCDs are very different than LEDs haha. Anyhow, I have no idea as I don't have an si drive car. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 5, 2012 Share Posted May 5, 2012 I just did mine on my car and it is not similar to the 05s its actaully 7-8 screws (it was liek 5 for the guages and 3 for the cluster glass) and very hard to take out it took me 1 hour mainly because some of them screws are really hard to get to. So many things to remove and I basically had to open and remove some parts on the steering column. i still have one screw out and have no idea where that one goes back into. interesting. I know for us (05s), we have to take out the plastic undercover (above our feet) first which consists of a few popits; then a couple screws to take out the plastic cover around the steering column, and then 3 screws (I think) for the actual instrument cluster. Not too bad. Here is how part of the 05 instrument cluster looks like inside: Link to comment Share on other sites More sharing options...
