chato Posted June 3, 2013 Share Posted June 3, 2013 hey all, so a couple weekends ago I replaced my leaking turbo inlet with a perrin. during the process I discovered a ton of really crispy and cracked vacuum lines (things dry out quick here in the desert) I am considering going with silicone hose to replace them, partly in hopes that it will hold up a little better over time in the dry and hot climate. I am in this car for the long haul. Anyone have any experience with this stuff (good or bad)? http://www.siliconeintakes.com/product_info.php?cPath=18&products_id=591&osCsid=fb08ac9b3f94a0d0d8343b6b738b2548 Link to comment Share on other sites More sharing options...
Max Capacity Posted June 3, 2013 Share Posted June 3, 2013 I have heard that silicone is not good to use on the intake side. It's not good for the O2 sensors. Just stick with regular vacuum hose from the auto parts store, It's more important to zip tie and the ends. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BigTDogg MA Posted June 3, 2013 Share Posted June 3, 2013 I have heard that silicone is not good to use on the intake side. It's not good for the O2 sensors. That's the first I've heard of this? I get my silicone vac line from http://www.Hosetechniques.com Link to comment Share on other sites More sharing options...
Max Capacity Posted June 3, 2013 Share Posted June 3, 2013 One of my Audi buddies (FAA Engineer with a long back ground in Jet Engines) mentioned that when I was talking about using silicone gasket sealer in the intake side. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
chato Posted June 3, 2013 Author Share Posted June 3, 2013 I know that silicone gasket maker isn't' good for o2's, but I am pretty sure silicone tubing is safe (or at least I hope so because I have a silicone turbo inlet). anybody else out there running silicone vacuum tubing and want to chime in? Link to comment Share on other sites More sharing options...
technicalgarage Posted June 3, 2013 Share Posted June 3, 2013 I swapped all of my rubber vac lines over to silicone nearly 2 years ago. Haven't had any issues whatsoever. Link to comment Share on other sites More sharing options...
KCwagon Posted June 3, 2013 Share Posted June 3, 2013 I just replaced a bunch of the old/cracked rubber hoses with 4mm silicone hose. It seems like a much better solution vs. rubber lines. Link to comment Share on other sites More sharing options...
chato Posted June 4, 2013 Author Share Posted June 4, 2013 Thanks for the input guys. Think I am going to pull the trigger. will let you know how it turns out. Link to comment Share on other sites More sharing options...
Xplosivo1 Posted June 5, 2013 Share Posted June 5, 2013 I just replaced a bunch of the old/cracked rubber hoses with 4mm silicone hose. It seems like a much better solution vs. rubber lines. If I were to replace all my vacuum lines, would 4mm be the only size I need to buy? Link to comment Share on other sites More sharing options...
chato Posted June 6, 2013 Author Share Posted June 6, 2013 I believe there are a couple different diameters at different locations... I'lll let you know after I dig into it. Link to comment Share on other sites More sharing options...
Industry Posted June 16, 2013 Share Posted June 16, 2013 If I were to replace all my vacuum lines, would 4mm be the only size I need to buy? did anyone find the answer to this? Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 17, 2013 Share Posted June 17, 2013 There are several companies that make kits that contain length of about 4 different sizes of silicone vacuum hose. I think you can pick up one of the kits for about $40-$50. I bought one about 4 years ago for $39.95 and still have some of the hose left after doing 2 cars with it. Link to comment Share on other sites More sharing options...
SBT Posted June 17, 2013 Share Posted June 17, 2013 Last fall, when we did Hicksta's exhaust/turbo swap, we changed out every existing vacuum line we could get to and zip-tied every single one. IIRC, there were 3, possibly 4 different sizes with 4mm being the smallest. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
technicalgarage Posted June 17, 2013 Share Posted June 17, 2013 Looked through my old order and saw I had mostly 4 and 6mm hose. Crankcase breathers and the like are obviously not a part of those sizes. Link to comment Share on other sites More sharing options...
chato Posted June 17, 2013 Author Share Posted June 17, 2013 yup 4 an 6mm. I will measure later today and figure out how much I actually used. Not even close to the amount ordered from the link in the first post. Link to comment Share on other sites More sharing options...
keenster Posted February 28, 2014 Share Posted February 28, 2014 http://www.siliconehose.com/silicone-vacuum-tubing/ this site has a good deal as well. first thing on google Link to comment Share on other sites More sharing options...
MAP Posted March 1, 2014 Share Posted March 1, 2014 Has anyone figured out how many different diameter vacuum hoses are needed if the goal is to replace all the hoses on the engine? I'm going to have to do this. All the hoses on there are rock hard. Link to comment Share on other sites More sharing options...
chato Posted March 2, 2014 Author Share Posted March 2, 2014 a few feet of each of 4mm and 6mm should do the trick. Link to comment Share on other sites More sharing options...
MAP Posted March 2, 2014 Share Posted March 2, 2014 Thanks Chato. Did you go with silicone hoses or rubber? Link to comment Share on other sites More sharing options...
chato Posted March 2, 2014 Author Share Posted March 2, 2014 silicon. link to where I bought it is on the first page. Link to comment Share on other sites More sharing options...
Free Range Racing Posted May 17, 2014 Share Posted May 17, 2014 Has anyone figured out how many different diameter vacuum hoses are needed if the goal is to replace all the hoses on the engine? I'm going to have to do this. All the hoses on there are rock hard. If you're still looking to replace all the hoses that are rock-hard in the engine bay with silicone options, I just posted up a complete hose kit in the vendor forums. Trying to get the word out, so my apologies if you've seen this elsewhere today. http://legacygt.com/forums/showthread.php/initial-sale-thread-05-09-lgt-complete-engine-silicone-hose-225429.html Link to comment Share on other sites More sharing options...
