EPLegacyGT Posted April 19, 2010 Share Posted April 19, 2010 I have a question for the all savant of the Legacy. Would it be possible to stop the front amber turning signals from turning on at night when I turn my light switch on while still retaining the turn signal. Yeah thats a long one. I think this would improve the look of the car. If anyone has done this before or found an old post please let me know. Link to comment Share on other sites More sharing options...
Leke Posted April 19, 2010 Share Posted April 19, 2010 Yes, you can. The turn signal bulb is dual filament - one filament is for the turn signal, and the other is for the amber running light you're talking about. I have a picture somewhere that identifies which pin does what. There's three pins: one leads to the turn signal filament, the other is the parking light filament, and the third is ground (it's the middle pin). All you'd have to do is cut the wire that handles the parking light functionalities. Your turn signal would still work as their power runs through a separate wire. I've done something similar to this for a JDM application, and I can confirm that it works the way I described. I'm at the library right now, but I'll find you the picture when I get back home. Link to comment Share on other sites More sharing options...
scrcmull Posted April 21, 2010 Share Posted April 21, 2010 What would be the point of that? The basic point of having those "side markers" is so that some idiot knows where the corners of your car are and therefore doesn't drive too close to the yellow line ( from the opposite side of the road)and hit you. You haven't noticed how many dopes out there are driving close to the yellow line?? Must be a Massachusetts thing........good luck with that Link to comment Share on other sites More sharing options...
mazdaaspec Posted April 21, 2010 Share Posted April 21, 2010 EPLegacyGP, I thank you for bringing this up because I have be asking tons of people if you are able to do this in my town, even the dealership doesnt know. Leke thank you for that as well I am looking at it in a few hours. GREAT POST. Link to comment Share on other sites More sharing options...
N.sane Posted April 22, 2010 Share Posted April 22, 2010 Subscribed. Thank you, Leke Link to comment Share on other sites More sharing options...
a.lim Posted April 22, 2010 Share Posted April 22, 2010 What would be the point of that? The basic point of having those "side markers" is so that some idiot knows where the corners of your car are and therefore doesn't drive too close to the yellow line ( from the opposite side of the road)and hit you. You haven't noticed how many dopes out there are driving close to the yellow line?? Must be a Massachusetts thing........good luck with that I would think the drivers would see your headlights at night and during the daytime I hope they are able to see the car. No issues here. Link to comment Share on other sites More sharing options...
CCSubaru Posted April 23, 2010 Share Posted April 23, 2010 Anyone find out for sure which wire it is? Link to comment Share on other sites More sharing options...
Leke Posted April 24, 2010 Share Posted April 24, 2010 http://lh3.ggpht.com/_qjqv2cZkG50/S9Mvytldm6I/AAAAAAAAAQs/XAZ-B2antdY/Socket%20Mod%204.jpg Sorry it's taken me a while. Good news is that I just wrote my last exam. Done 3rd year, woot woot! Anywho, I saved this picture off the forums quite some time ago. I cannot remember who took it, so forgive me for not providing the owner. I've modified it and blacked out some information/explanations that aren't related to this mod. This is a picture of the plug that runs from your car and plugs into the headlight turn signal bulb. You can see which wire it is that you need - which is the one denoted with the red X. This is the wire you'd need to cut. I'm not responsible if you damage your car doing this. Though, I've done something similar to get jdm lights to work. Link to comment Share on other sites More sharing options...
EPLegacyGT Posted April 24, 2010 Author Share Posted April 24, 2010 Thanks for the picture. Ill try and cover the filament with something instead of cutting the wire. I also finished my exams in my 3rd year of mechanical engineering. Ill let you know how this little project turns out. Link to comment Share on other sites More sharing options...
Leke Posted April 24, 2010 Share Posted April 24, 2010 I also finished my exams in my 3rd year of mechanical engineering. software eng. >> mechanical eng. jk Link to comment Share on other sites More sharing options...
EPLegacyGT Posted April 25, 2010 Author Share Posted April 25, 2010 Lol, ouch. Get back to you when i try shutting the ambers. Link to comment Share on other sites More sharing options...
mazdaaspec Posted April 25, 2010 Share Posted April 25, 2010 Leke, I would make out with you if I could but you would kick me in the baby maker. This thread was amazing. Link to comment Share on other sites More sharing options...
bettner12 Posted May 6, 2010 Share Posted May 6, 2010 i think that de-pinning the OEM connector for the running lights would be a cleaner way of doing it with out permanently modifying you're wiring harness by cutting wires. Some connections are harder than others but you can pull out the pins, which would be equivalent of cutting the wire. Link to comment Share on other sites More sharing options...
Leke Posted May 7, 2010 Share Posted May 7, 2010 Very good suggestion! Guys keep in mind exactly what plug you're looking at! That's the plug that runs from your car's wiring harness. I was doing this on my JDM setup and ended up confusing myself accidentally. I soldered a turn signal socket into the parking light connectors.. Easy fix, but still, a silly mistake. Link to comment Share on other sites More sharing options...
EPLegacyGT Posted July 12, 2010 Author Share Posted July 12, 2010 I finally had the time to clear my headlights and disable the orange running light and makes for a very clean look. Pics to come soon. (Once the gf returns the digital camera) Link to comment Share on other sites More sharing options...
DocHolladay23 Posted July 12, 2010 Share Posted July 12, 2010 with that being answered, how about something I've been wanting to do for a while, make it so the mirror signals are always on with the headlights like the turn signals [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
