dan_m Posted December 30, 2008 Share Posted December 30, 2008 my mechanic said that the damage shown on this pic is sufficient to have my entire tranny replaced, what do you guys think? This damage was discovered when he was replacing my clutch. Gearing and syncs still work great btw. http://www.pbase.com/frankcoti/image/107581051.jpg thx. Link to comment Share on other sites More sharing options...
Opie Posted December 31, 2008 Share Posted December 31, 2008 You don't need a new tranny...get one of these: http://www.smart-service.com/store-tranquil-sleeve-kit.html Link to comment Share on other sites More sharing options...
rao Posted December 31, 2008 Share Posted December 31, 2008 +1, as usual Opie has the goods Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2008 Share Posted December 31, 2008 Except I believe people had trouble fitting them to LGT. Search, people were investigating alternatives to crappy stock TOB. Link to comment Share on other sites More sharing options...
dan_m Posted December 31, 2008 Author Share Posted December 31, 2008 ...and search I did http://legacygt.com/forums/showthread.php?t=79954&highlight=Sleeve+Kit it seems like the sleeve kit from PDM doesn't fit the snout of the LGT transmission properly, or has someone managed to get it to work ( TSK2 or TSK3 )? hopelessly lost .......... Link to comment Share on other sites More sharing options...
paparoo Posted January 1, 2009 Share Posted January 1, 2009 I will try to clarify the applications of the PDM sleeve kits. TSK1 is for all N.A. (non-turbo) Legacy, Impreza, Forester, Baja models, all engines, except 1993 Impreza 2WD, 1.8, 5spd sedans. The original bearing number is 30502AA051. TSK2 is for 91-94 & 2005-up Turbo Legacy, 2002-2005 WRX, 2004 Turbo Forester and Baja. The clutch slave cylinder is in behind the clutch fork so it can push forward on the fork, thus pulling back on the bearing. The original bearing number is 30502AA080. TSK3 is for all 2005-up Turbo models & 2006-up WRX. These should all have the push type clutch. The clutch slave cylinder is in front of the clutch fork, just like the N.A., so it can push back on the fork. The original bearing number is 30502AA120. You can call the dealer with your vin & ask which bearing is in your car. The sleeve is warranted for life against failure. The bearing is warranted for 1 year. Sometimes damage to the trans quill will prevent the sleeve from sliding on. Debur the quill with sand paper or a file in the damage areas only. It is critical that the sleeve fits snugly to prevent distortion upon tightening the set screws. A light tap on the shoulder should set it in place. Every sleeve is test fitted on an actual Subaru transmission. After 30 years working on Subarus, I know how frustrating it is for something not to work right. If it appears to be too tight return it or call PDM @ 1-877-736-2775 and they will make it right. They have sold almost 6000 of these kits in the last 5 years. That would not happen if there was a consistant problem with the product. The 2005 Turbo Legacy seems to be the biggest culprit, but the Forester, WRX & Baja have the same problem. It seems that Subaru reverted to the push type clutch in a effort to reduce the shock to the transmission causing failure. You can only put limited power to a push type clutch thus the slippage or reduced impact. I started turbo-ing Subarus in 1978. I could not get a cluth to hold the power. I modified the flywheel in order to use a VW racing clutch. It held but a woman couldn't drive it for the pedal pressure. I hope this helps. Paparoo Link to comment Share on other sites More sharing options...
rao Posted January 1, 2009 Share Posted January 1, 2009 Now THAT is an excellent first post Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
dan_m Posted January 1, 2009 Author Share Posted January 1, 2009 yup! I'll be ordering my PDM sleeve kit shortly! thx. paparoo =) Link to comment Share on other sites More sharing options...
MYGSXR1000 Posted January 2, 2009 Share Posted January 2, 2009 nice right up thanks... Link to comment Share on other sites More sharing options...
MOMSWGN Posted January 2, 2009 Share Posted January 2, 2009 Installed the TSK3 with my new tranny. No problems with install with the TSK3 on the 05 LGT tranny. Problems were encountered with trying to install the TSK2 on the 05 tranny. Link to comment Share on other sites More sharing options...
MonkeyHermit Posted January 3, 2009 Share Posted January 3, 2009 Installed the TSK3 with my new tranny. No problems with install with the TSK3 on the 05 LGT tranny. Problems were encountered with trying to install the TSK2 on the 05 tranny. I have the TSK3 kit and it wouldn't fit my tranny Did you have to do anything special or it slid right on with no trouble? Link to comment Share on other sites More sharing options...
MOMSWGN Posted January 3, 2009 Share Posted January 3, 2009 First of all I gave the guys my VIN and they told me I needed the TSK3. It fit without any problems. Link to comment Share on other sites More sharing options...
blackfang Posted January 3, 2009 Share Posted January 3, 2009 Definitely go with the sleeve kit before spending that kind of money. We replace them from time to time when doing clutch jobs depending if there is any damage. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
caramall2 Posted January 8, 2009 Share Posted January 8, 2009 Would you guys suggest always doing this on a clutch replacement? (E.g. Dealer's putting in an ACT clutch for me soon...50k on car.) Link to comment Share on other sites More sharing options...
paparoo Posted January 8, 2009 Share Posted January 8, 2009 I posted under a new thread about the LGT throw out bearing problem. I reccommend you read it before installing your clutch. It is in the transmission forumtitled "LGT clutch release bearing" Paparoo Link to comment Share on other sites More sharing options...
PeterJMC Posted January 8, 2009 Share Posted January 8, 2009 Is smart-service.com the only place to get the tsk3? I have an ACT clutch sitting in my room ready for install. Link to comment Share on other sites More sharing options...
