kcmusa Posted June 29, 2007 Share Posted June 29, 2007 So we all know the AP is not out for the 07 GT and I have this DP sitting here waiting to be installed. is it ok to install and run just a DP without engine management? will i get a cel? Link to comment Share on other sites More sharing options...
rao Posted June 29, 2007 Share Posted June 29, 2007 It is ok; you will get a CEL for cat efficiency. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
DeepFreeze2 Posted June 29, 2007 Share Posted June 29, 2007 ^^What he said^^ Been running that way for a while. No cruise control and your dash lights up like a Christmas tree. YA RLY!!! Home of +2500 useless posts!!!! Link to comment Share on other sites More sharing options...
kcmusa Posted June 29, 2007 Author Share Posted June 29, 2007 you lost your cruise? ummm maybe i will wait. Link to comment Share on other sites More sharing options...
qikslvr Posted June 29, 2007 Share Posted June 29, 2007 Is it a catted or cattless DP? This may make a difference. Let's kick this pig! Link to comment Share on other sites More sharing options...
AKLGT Posted June 29, 2007 Share Posted June 29, 2007 whenever you take out any of the cats, you'll most likely throw a CEL. if so, then the CEL will automatically turn off your cruise. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
zhabodav Posted June 29, 2007 Share Posted June 29, 2007 I can vouch for no CEL... I have an 07 GT and a catless Megan Racing DP...installed it myself.... It costs very little compared to others...and you can get an 02 censor extension...thats what I got.....1 downpipe + no cat + 02 extension = NO CEL . Good luck Right now I have full Megan Racing TBE, Perrin Pulley + Short ram intake, and a bunch of exteriors....as soon as cobb releases an AP I am on it Link to comment Share on other sites More sharing options...
kcmusa Posted July 2, 2007 Author Share Posted July 2, 2007 I did get the cobb catted DP, I think it has a spot for the o2 sencor? if so will I be ok, no cel? Link to comment Share on other sites More sharing options...
DeepFreeze2 Posted July 2, 2007 Share Posted July 2, 2007 whenever you take out any of the cats, you'll most likely throw a CEL. if so, then the CEL will automatically turn off your cruise.+1. But not everyone has the same experiences. The CEL code can be read and cleared with an OBD II scanner in the meantime. YA RLY!!! Home of +2500 useless posts!!!! Link to comment Share on other sites More sharing options...
speeddr7 Posted July 2, 2007 Share Posted July 2, 2007 spark plug non fouler mods works well. Also have an 07 and had no light....most of the time Who needs tickets to the gun show? Link to comment Share on other sites More sharing options...
qikslvr Posted July 2, 2007 Share Posted July 2, 2007 I did get the cobb catted DP, I think it has a spot for the o2 sencor? if so will I be ok, no cel? They all have at least one bung for an O2 sensor. I believe the Cobb DP has an additional bung before the cat (upstream) for installing a wideband O2 sensor for tuning. This will not prevent a CEL. It sounds like if you can find an O2 sensor extension; It will hide part of the O2 sensor from the exhaust stream and in effect reduce the reading of the O2 sensor and eleminate the CEL. Let's kick this pig! Link to comment Share on other sites More sharing options...
musclecpa Posted July 3, 2007 Share Posted July 3, 2007 For sure you'll get P0420 - cat efficiency, cause I've done it. But once you flash to Stage II, it will go away. Link to comment Share on other sites More sharing options...
badfish11 Posted July 8, 2007 Share Posted July 8, 2007 So we all know the AP is not out for the 07 GT and I have this DP sitting here waiting to be installed. is it ok to install and run just a DP without engine management? will i get a cel? Did you wind up putting the downpipe in? Link to comment Share on other sites More sharing options...
sexylegacy Posted July 8, 2007 Share Posted July 8, 2007 what is the size and thread pitch of the o2 sensor?? Link to comment Share on other sites More sharing options...
keysersoze Posted July 9, 2007 Share Posted July 9, 2007 http://www.rallitek.com/raoxsead.html http://us.st11.yimg.com/us.st.yimg.com/I/yhst-49187380673845_1955_7897464 RalliTEK Oxygen Sensor Adaptor 3C1151 Link to comment Share on other sites More sharing options...
jpapworth Posted July 9, 2007 Share Posted July 9, 2007 You can get a spark plug anti-fouler. 18mmx1.5 pitch works. Then you drill the center out with a 1/2" drill bit. Take all of 5 minutes and the anti-fouler costs $5 for a pack of 2. If you don't have a drill bit they are about $10. There is a member here who sells them already drilled out for $14, I believe his name is Jordanz23. Link to comment Share on other sites More sharing options...
sexylegacy Posted July 9, 2007 Share Posted July 9, 2007 I've got the tools to drill them, I just couldn't find the diameter and pitch. Thanks jpap. Link to comment Share on other sites More sharing options...
jpapworth Posted July 9, 2007 Share Posted July 9, 2007 No problem, oh you may want to double up and use 2 anti-foulers. Sometimes 1 anti-fouler is not enough to pull the sensor out of the exhaust flow. Link to comment Share on other sites More sharing options...
badfish11 Posted July 9, 2007 Share Posted July 9, 2007 I want to get a dp and install myself with this method, I just have no idea where the sensor is or anything like that. I guess I'll just go and peak around in there... Link to comment Share on other sites More sharing options...
Paradiso Posted July 9, 2007 Share Posted July 9, 2007 Does it really make sense to install UP/DP/Catback without an AP? Seems to me that you are spending a bunch of money and taking a chance on warranty hassles for a minimum gain. How much of a result can you expect doing this without a tune??? Link to comment Share on other sites More sharing options...
kcmusa Posted July 9, 2007 Author Share Posted July 9, 2007 I am waiting for the 07 GT access port, i have the DP now and was thinking about installing it. Link to comment Share on other sites More sharing options...
jpapworth Posted July 9, 2007 Share Posted July 9, 2007 There are ways to tune without the AP. You can do it without the AP, and leave alot of power on the table. You can also tune with open source tuning and a tactrix cable. Start with small adjustments and be sure to datalog. Or you can go to a tuner and dyno tune. The AP is kinda cool, but I hate hearing that attitude that you MUST HAVE the AP to do ANYTHING. Start reading, start datalogging, and start visiting some opensource forums (openecu.org, XPT Tuning, Scoobypedia, ecuflash, and enginuity) and begin learning for youself. Even if you don't tune, datalogging for $80 with ecuexplorer or enginuity is fun and pretty amazing by itself. Link to comment Share on other sites More sharing options...
sexylegacy Posted July 10, 2007 Share Posted July 10, 2007 This is what I am hoping Sean at Rallitek will do for me at some point, just to get a base tune until I can either get an Accessport, or get a custom Dyno tune. It doesn't take much to load a standard Stage II map onto your ECU. Link to comment Share on other sites More sharing options...
poopy Posted July 10, 2007 Share Posted July 10, 2007 There are ways to tune without the AP. You can do it without the AP, and leave alot of power on the table. You can also tune with open source tuning and a tactrix cable. Start with small adjustments and be sure to datalog. Or you can go to a tuner and dyno tune. The AP is kinda cool, but I hate hearing that attitude that you MUST HAVE the AP to do ANYTHING. Start reading, start datalogging, and start visiting some opensource forums (openecu.org, XPT Tuning, Scoobypedia, ecuflash, and enginuity) and begin learning for youself. Even if you don't tune, datalogging for $80 with ecuexplorer or enginuity is fun and pretty amazing by itself. you can't tune a 07 with these methods! the only option right now is the utec delta, which doesn't adjust avcs. i've been running cobb tbe(cat-less), avo tmic, pulley, and a header for 2500 miles w/o a cel. i used the 02 extender from rallitek. the car will run real rich, which hurts performance, but is safe. Link to comment Share on other sites More sharing options...
