spudd Posted July 6, 2014 Share Posted July 6, 2014 Anyone use either of these clutch lines? http://www.jscspeed.com/catalog/Sub..._Steel_Clutch_Lines_for_02_05_Subaru_WRX.html Preferences or issues with either? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 9, 2014 Share Posted July 9, 2014 Will that even work on your cars ? Why won't a new OEM line work ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
spudd Posted July 9, 2014 Author Share Posted July 9, 2014 The oem line is the same part for a wrx and my 2000 outback. I figured why not upgrade, cheap enough Link to comment Share on other sites More sharing options...
kirshnerd Posted July 9, 2014 Share Posted July 9, 2014 I highly doubt you'll fee a difference in the clutch line being SS braided or OEM. There's too much play and movement elsewhere in the system, unlike brakes where SS braided lines hold the higher pressure of pushing harder on a pedal that's not moving when you push harder. Link to comment Share on other sites More sharing options...
