jeffao Posted February 7, 2013 Share Posted February 7, 2013 Is there a separate fuse for the 12v auxiliary outlet under the radio? The one under the arm rest works fine. I was pumping up a tire, shut off the pump to let it cool for a bit, started it back up, and nothing. My car is a 2005 2.5l btw Link to comment Share on other sites More sharing options...
.Catalyst. Posted February 7, 2013 Share Posted February 7, 2013 My LGT has two different fuses for those outlets. I think it was like CIG and ACC 12V (console box). It's been quite a while but when looking at the chart on the fuse lid it made sense. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
jeffao Posted February 7, 2013 Author Share Posted February 7, 2013 Thank you! I will have to look at that as soon as there's light out. Where is the fuse panel in this car? Passenger's, or drivers side? Link to comment Share on other sites More sharing options...
12sechatch Posted February 8, 2013 Share Posted February 8, 2013 Do any cars have the fuse box on the passenger side? Link to comment Share on other sites More sharing options...
SP3C7R3 Posted February 8, 2013 Share Posted February 8, 2013 I had problems pumping up a tire with the front cig lighter;kept blowing fuses. Just make sure to use the center console one, and you should be fine. Sent from my DROID DNA Link to comment Share on other sites More sharing options...
