cjl0792 Posted November 6, 2010 Share Posted November 6, 2010 05 lgt stage 2 blown 5th gear. i know its in the wrong thread just wanted some help. anything common or has any one already done it? Link to comment Share on other sites More sharing options...
Beefaru Posted November 6, 2010 Share Posted November 6, 2010 The '80's 5MT tranny had an oil dripper/channeler tray that would take flung oil from the main gear area 1-4, catch it, and channel/drip it onto 5th gear. I haven't seen the '05-09 tranny pulled apart, but in the old ones, 5th gear was "outside" of the main gear area and needed that tray to lubricate 5th. Just a thought. Link to comment Share on other sites More sharing options...
ehsnils Posted November 6, 2010 Share Posted November 6, 2010 If not under drivetrain warranty the easiest alternative would be to get a new (used) gearbox or a complete driveline from a STi. (Gearbox+Rear Diff and also control unit for the DCCD.) If you get an used gearbox make sure that the differential gearing is the same or you will have a sorry center diff. Of course - you may be able to just pull the gearbox apart and replace the gears, but you will have to clean the gearbox thoroughly to get rid of metal shavings. Link to comment Share on other sites More sharing options...
mattg Posted November 6, 2010 Share Posted November 6, 2010 http://legacygt.com/forums/showthread.php/broken-5mt-138116.html?t=138116 Link to comment Share on other sites More sharing options...
cjl0792 Posted November 8, 2010 Author Share Posted November 8, 2010 thank you for your help. hopefully i will get to take it out and apart this week in my bay. got to check with the boss first. Link to comment Share on other sites More sharing options...
